IcePrick Posted June 18, 2012 Share Posted June 18, 2012 If you have a fairly stock XX, I need the distance from the leading edge of underside of the lower cowl to the ground as a starting point for the ZX-14 swap suspension setup. Preferably not while it's on the stand, if at all possible... I had it written down (along with a lot of other stuff), but I can't find it now. Much appreciated if anyone can manage it! Quote Link to comment Share on other sites More sharing options...
tomek Posted June 18, 2012 Share Posted June 18, 2012 About 115 mm measured at the front chin , bike off the stand , no load ( rider) . Ideally you should be comparing this measurement with you on the bike , otherwise if non stock springs are stiffer then oem you`ll end up with higher ride height . 25.4 mm = 1 inch Quote Link to comment Share on other sites More sharing options...
IcePrick Posted June 23, 2012 Author Share Posted June 23, 2012 About 115 mm measured at the front chin , bike off the stand , no load ( rider) . Ideally you should be comparing this measurement with you on the bike , otherwise if non stock springs are stiffer then oem you`ll end up with higher ride height . 25.4 mm = 1 inch Missed the reply - thanks! I'll be in the garage again this weekend! Good point on the stiffer springs, I'll have to look the rates up. But it's really just to get an initial rough starting point to adjust from. Quote Link to comment Share on other sites More sharing options...
