jon haney Posted January 3, 2011 Share Posted January 3, 2011 An experienced fellow racer said that seven seasons of drag racing is way longer than recommended before replacing. Don't really want to spend the dough for aftermarket. "Low-mileage" means anything under 30K unless it's had a real hard life......like mine. Also interested in inner hub for same. Quote Link to comment Share on other sites More sharing options...
E.Ness Posted January 4, 2011 Share Posted January 4, 2011 I have a brand new clutch set with springs for 97. never used. make me an offer if ok, I will ship it out to you. E. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted January 4, 2011 Share Posted January 4, 2011 WTB low-mileage clutch basket for FI Bird I have a brand new clutch set with springs for 97. Quote Link to comment Share on other sites More sharing options...
HANKSXXX Posted January 4, 2011 Share Posted January 4, 2011 I have a brand new clutch set with springs for 97. never used. make me an offer if ok, I will ship it out to you. E. PM sent on the clutch...Hank Quote Link to comment Share on other sites More sharing options...
jon haney Posted January 4, 2011 Author Share Posted January 4, 2011 I have a brand new clutch set with springs for 97. never used. make me an offer if ok, I will ship it out to you. E. Don't need plates. Just the basket and inner hub. Thanks anyway. Quote Link to comment Share on other sites More sharing options...
HANKSXXX Posted January 4, 2011 Share Posted January 4, 2011 Jon, I have a complete clutch assembly from a carbed (97-98) BB. Ask your drag race buddies if that would be an bolt in upgrade. You'd end up with 9 plates instead of seven and 5 springs instead of 6. I know on the Turbos that an early clutch is preferable as it will hold 250HP with HD Barnett springs. The later clutch seems to give up sooner and most guys go to a lockup. It's just a thought anyhow so if it checks out and you're interested, get in touch... Hank Quote Link to comment Share on other sites More sharing options...
jon haney Posted January 4, 2011 Author Share Posted January 4, 2011 Jon, I have a complete clutch assembly from a carbed (97-98) BB. Ask your drag race buddies if that would be an bolt in upgrade. You'd end up with 9 plates instead of seven and 5 springs instead of 6. I know on the Turbos that an early clutch is preferable as it will hold 250HP with HD Barnett springs. The later clutch seems to give up sooner and most guys go to a lockup. It's just a thought anyhow so if it checks out and you're interested, get in touch... Hank Yes, I have a lock-up, so I have to go with the 6 spring model. BTW, I have no drag racing peers who are running a blackbird. I catch a lot of shit just running a Honda. They only make fun of me cause I keep taking their money. Quote Link to comment Share on other sites More sharing options...
HANKSXXX Posted January 4, 2011 Share Posted January 4, 2011 Jon, I have a complete clutch assembly from a carbed (97-98) BB. Ask your drag race buddies if that would be an bolt in upgrade. You'd end up with 9 plates instead of seven and 5 springs instead of 6. I know on the Turbos that an early clutch is preferable as it will hold 250HP with HD Barnett springs. The later clutch seems to give up sooner and most guys go to a lockup. It's just a thought anyhow so if it checks out and you're interested, get in touch... Hank Yes, I have a lock-up, so I have to go with the 6 spring model. BTW, I have no drag racing peers who are running a blackbird. I catch a lot of shit just running a Honda. They only make fun of me cause I keep taking their money. Keep up the good work... :icon_clap: Quote Link to comment Share on other sites More sharing options...
jon haney Posted January 7, 2011 Author Share Posted January 7, 2011 BUMP. Quote Link to comment Share on other sites More sharing options...
XX4me Posted January 9, 2011 Share Posted January 9, 2011 Either clutch will work unless you have a lock up. Difference is just the number of steels and disks. To stop slippage I ran a '98 clutch in my '02 turbo before I went with a Falicon billet job. Wanted the higher number of steels and plates in conjunction with heavier aftermarket VTX springs. It worked, no more slips past 235hp. Quote Link to comment Share on other sites More sharing options...
HANKSXXX Posted January 9, 2011 Share Posted January 9, 2011 Either clutch will work unless you have a lock up. Difference is just the number of steels and disks. To stop slippage I ran a '98 clutch in my '02 turbo before I went with a Falicon billet job. Wanted the higher number of steels and plates in conjunction with heavier aftermarket VTX springs. It worked, no more slips past 235hp. Forrest, did you leave the factory "judder spring" in when you added the early clutch assy and if not, how did you modify the assembly? Quote Link to comment Share on other sites More sharing options...
XX4me Posted January 9, 2011 Share Posted January 9, 2011 Hank I don't remember modifying anything, seems like it just swapped out. Quote Link to comment Share on other sites More sharing options...
HANKSXXX Posted January 10, 2011 Share Posted January 10, 2011 Hank I don't remember modifying anything, seems like it just swapped out. Thanks Forrest...when you coming east? Some people take out the judder spring and have to machine a steel disc and add a fiber or something like that. It's supposed to make the clutch more controllable for drag racing. Come to think of it, mighta been Dean who mentioned that. Just wondering about street use, which you've answered... Note to self...KISS Quote Link to comment Share on other sites More sharing options...
jon haney Posted January 10, 2011 Author Share Posted January 10, 2011 Hank I don't remember modifying anything, seems like it just swapped out. Thanks Forrest...when you coming east? Some people take out the judder spring and have to machine a steel disc and add a fiber or something like that. It's supposed to make the clutch more controllable for drag racing. Come to think of it, mighta been Dean who mentioned that. Just wondering about street use, which you've answered... Note to self...KISS Search for "Clutch Cushion" in the garage section. I believe there was a discussion of the mod you are referring to. Quote Link to comment Share on other sites More sharing options...
HANKSXXX Posted January 10, 2011 Share Posted January 10, 2011 Hank I don't remember modifying anything, seems like it just swapped out. Thanks Forrest...when you coming east? Some people take out the judder spring and have to machine a steel disc and add a fiber or something like that. It's supposed to make the clutch more controllable for drag racing. Come to think of it, mighta been Dean who mentioned that. Just wondering about street use, which you've answered... Note to self...KISS Search for "Clutch Cushion" in the garage section. I believe there was a discussion of the mod you are referring to. Thanks Jon, I'll take a look Hank Quote Link to comment Share on other sites More sharing options...
