Zero Knievel Posted November 13, 2010 Share Posted November 13, 2010 There's a section devoted to it the valves, but I don't see anything on inspection...just on taking things apart and putting them back together. Quote Link to comment Share on other sites More sharing options...
Redbird Posted November 13, 2010 Share Posted November 13, 2010 Been awhile, but I'm assuming you're in the motor section. Try the maintenance section. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted November 13, 2010 Author Share Posted November 13, 2010 Been awhile, but I'm assuming you're in the motor section. Try the maintenance section. Thanks. Manual said page 3-8. Instead that takes you to spark plugs. Instructions were on 3-11. Another question, how's the easiest way to remove the CCT and get it back in with minimal hassle? They mention a "stopper tool" but I'm hoping I saved that metal bit that came with my CCT. Quote Link to comment Share on other sites More sharing options...
John01XX Posted November 13, 2010 Share Posted November 13, 2010 CCT is easy Stopper tool = any small screwdriver type tool used to wind up the CCT spring Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted November 13, 2010 Share Posted November 13, 2010 CCT removal is simple just remove the bolts. When you put it back in use a small flat screw driver to retract the spring. It's a bit of a pain holding the screw driver in place while putting it back in the bike, a extra hand helps but it is doable by yourself. Quote Link to comment Share on other sites More sharing options...
