No Sparks
joeknott
My 1999 Blackbird must have a broken wing and I really need some assistance from you tech guys. I wanna come to NEXXT and my bird is sick!
Cylinders 1 and 4 are not sparking
I have 12 volts at the yellow wire at the coil. The bike does run on 2 of the 4 cylinders
Need some help in diagnosing the coil as I do not have the voltage adapted for the BOM
What reading should I get at the yellow wire with the bike running?
Do the coils go bad? Are there any other issues to keep it from sparking?
It does start and FI light does not stay on.
Any info you can offer would be a HUGE help.
Thanks,
Joe
  • 3 weeks later...
well it turns out that the "loom" was the entire problem. The horn not working, the turn signals not working unless the front and rear brakes were applied at the same time, AND the 1&4 cylinders not sparking were all fixed when we took out the connector and soldered the wires together. Thanks for your help fellas!
