zr1_170 Posted August 1, 2010 Share Posted August 1, 2010 Found a small fuel leak on the bike. It turns out someone worked on it and did not return the spring clamps on the fuel lines going to the tank. When I pulled them off fuel start running out every where. My question is I thought the fuel valve was vacuum operated? Is the valve I have bad if it pours fuel when the bike is not running? Thanks Mike Quote Link to comment Share on other sites More sharing options...
brianmacza Posted August 2, 2010 Share Posted August 2, 2010 Found a small fuel leak on the bike. It turns out someone worked on it and did not return the spring clamps on the fuel lines going to the tank. When I pulled them off fuel start running out every where. My question is I thought the fuel valve was vacuum operated? Is the valve I have bad if it pours fuel when the bike is not running? Thanks Mike You may have a hole in the diaphram - I started finding my bike occasionally had hydraulic lock - diaphram leaked and filled the cylinders with raw fuel. Ended up with a new diaphram and an oil/filter change just in case. Quote Link to comment Share on other sites More sharing options...
zr1_170 Posted August 2, 2010 Author Share Posted August 2, 2010 Cool so I guess the valve is rebuild-able? Quote Link to comment Share on other sites More sharing options...
brianmacza Posted August 3, 2010 Share Posted August 3, 2010 Cool so I guess the valve is rebuild-able? Yup... mine wasn;t torn so that was easy. Its an off the shelf part from your friendly Honda stealership Quote Link to comment Share on other sites More sharing options...
