Pat830 Posted April 27, 2010 Share Posted April 27, 2010 Service Honda, Ron Ayers, where? I want it promptly, not from somebody that will take a week to get it in their UPS shipment. Honda Part Number 31600-MAT-E01 for my 2000XX Three yellow wires in one plug, two red/yellow two green and one black wire in the other plug. Thanks, Pat Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted April 27, 2010 Share Posted April 27, 2010 Do yourself a favor and upgrade to the R1's Rectifier if I remember right they are even cheaper. I've never heard of one failing either. Do a search if you need more info someone was even making a harness to swap them. Quote Link to comment Share on other sites More sharing options...
Pat830 Posted April 27, 2010 Author Share Posted April 27, 2010 Do yourself a favor and upgrade to the R1's Rectifier if I remember right they are even cheaper. I've never heard of one failing either. Do a search if you need more info someone was even making a harness to swap them. I've seen the thread showing Mike making the harness for the various years. I was thinking about it, but my rectifier had more wires than I was expecting for a 2000 model XX. What do I do with the two red/yellow wires and the two green wires that are plugged into the OEM rectifier, I don't think the R1 rectifier has the same amount of wires going into it? AND Yamaha parts are notorious for being slow to ship, I have a week long ride coming up shortly, I don't want a backordered part messing that up. Quote Link to comment Share on other sites More sharing options...
redxxrdr Posted April 28, 2010 Share Posted April 28, 2010 Pat, Ron Ayers has good pricing. But they tell you up front that they aren't fast. I found this LINKthat talks about the extra wires on the 00XX and how to connect a R1 rectifier. PM, Rich ( Hobicus). He knows vendors that can get what you need fast. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted November 16, 2010 Share Posted November 16, 2010 I'll add on here. For a CBR1100XX....1999 model. R/R from Honda - 31600-MAT-E01 - MSRP: $172.78 - Your Price: $125.44 R/R for YZF R-1 (1999) - 4JH-81960-01-00 - MSRP: $109.90 - Your Price: $70.40 Above prices from Ronayers.com. Now, pics of both R/R units are below. As you can see, the R-1 version shows a plugin but no harness. The other is stock, but then I find this website.... http://www.regulatorrectifier.com/catalog/...tor-Rectifier-1 ... $79.99 http://www.regulatorrectifier.com/catalog/...lator-Rectifier ... $119.99 http://www.regulatorrectifier.com/catalog/...lator-Rectifier ... $129.95 BartonMD makes pigtail connectors for the R-1 R/R. Which option do you think is better? Quote Link to comment Share on other sites More sharing options...
beestoys Posted November 20, 2010 Share Posted November 20, 2010 Here is a good vendor http://www.ricksmotorsportelectrics.com/ As for regulator there is the R1 or here is another setup that works the same as it doesn't shunt to ground like the stock http://roadstercycle.com/index.htm I am running a Electrosport high output stator with the above R/R from roadster and have no issues with charging. Quote Link to comment Share on other sites More sharing options...
cbrxxquad Posted November 20, 2010 Share Posted November 20, 2010 Here is a good vendor http://www.ricksmotorsportelectrics.com/ As for regulator there is the R1 or here is another setup that works the same as it doesn't shunt to ground like the stock http://roadstercycle.com/index.htm I am running a Electrosport high output stator with the above R/R from roadster and have no issues with charging. Just when I get jaded thinking I have seen it all, thanks for the link. Reverse three wheeler, reverse box, and much more. Got any more links like that? Quote Link to comment Share on other sites More sharing options...
CALCXX Posted November 26, 2010 Share Posted November 26, 2010 I have a 99 - R1 regulator on my XX for three years now and installed Mikes harness. I also installed a new 14AH battery. WORKS GREAT!!! Quote Link to comment Share on other sites More sharing options...
pdaddy21 Posted June 2, 2011 Share Posted June 2, 2011 can you adapt a r1 rectifier to a 1997 xx and if so what year model r1 rectifier do i use??? Quote Link to comment Share on other sites More sharing options...
HANKSXXX Posted June 2, 2011 Share Posted June 2, 2011 I just bought the kit from Roadstercycle to use on my 97. Jack is very easy to deal with and ships immediately but my delivery was delayed by USPS. If you go this route, call him and get expedited delivery. The Yamaha part # is on his website and connectors are available through Eastern Beaver but I chose to pay a couple bucks more and get everything from Jack. Installing this week... Hank Quote Link to comment Share on other sites More sharing options...
matthend Posted June 8, 2011 Share Posted June 8, 2011 can you adapt a r1 rectifier to a 1997 xx and if so what year model r1 rectifier do i use??? Yes, have one on my 97. IIRC, the r1 and r6 ones are interchangeable. I will try to dig up which year i used Quote Link to comment Share on other sites More sharing options...
HANKSXXX Posted June 8, 2011 Share Posted June 8, 2011 I just bought the kit from Roadstercycle to use on my 97. Jack is very easy to deal with and ships immediately but my delivery was delayed by USPS. If you go this route, call him and get expedited delivery. The Yamaha part # is on his website and connectors are available through Eastern Beaver but I chose to pay a couple bucks more and get everything from Jack. Installing this week... Hank and as an update, the reg/rec holds a steady 14.2-14.3 volts. The waterproof connectors are extremely well made. The wire ends snap into the waterproof connectors and the connectors snap into the reg/rec. I mounted it in the stock location but had to trim the top fin slightly...no big deal. All in all, it looks to be a real upgrade. The reg/rec is used on 07 and up R-1's and FJR 1300's. Hank Quote Link to comment Share on other sites More sharing options...
dehning Posted June 9, 2011 Share Posted June 9, 2011 Just FYI, I have not had to replace the Regulator on my Blackbird yet, but the one on my VFR800 started failing a while back so I eventually made the switch to an R1 regulator. I was actually able to get the R1 regulator under my fairings without cutting any of the cooling fins. It has worked flawlessly every since: Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted June 10, 2011 Share Posted June 10, 2011 Went looking for some more info but some of the links seem to be dead. Would be nice to get all the info together in one thread, and sticky it. BartonMD any chance you have any pics or instructions you made up we could use? Quote Link to comment Share on other sites More sharing options...
