Re: Rear RR shock with 16 KG spring install question
RickXX
I ‘m proceeding with the 900 RR rear shock installation. For those who have done the installation, what are the setting for the preload ramp, rebound and compression? :roll:
My weight is 170 lbs. without gear so I guess another 20 lbs. with gear. I also have the 3 Givi cases. I also ride 2 up sometimes (she’s 115 lbs.)
Should I set the preload to the max of 7? I got the 16KG spring on the RR shock before installing it. I know I have to measure the sag but since the preload is hard to get at, it would be easier to take an educated guess at it first
What about the rebound and compression, should they be set in the middle to start? ? :roll:
Rick :-o
