Hank.SD Posted October 26, 2009 Share Posted October 26, 2009 Does anyone know if a 97 exhaust is the same as a 99? They look identical on the fiche, and the price is the same, but bikebandit has different PNs. The 99 is FI yes?.... I'm hoping to do an exhaust swap between the two (one is aftermarket, one is stock). Thanks! Quote Link to comment Share on other sites More sharing options...
JB4XX Posted October 26, 2009 Share Posted October 26, 2009 you'll be ok Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted October 26, 2009 Share Posted October 26, 2009 It will fit. The cylinder head has the same spacing and mount points, and the frame has the same mount points. Quote Link to comment Share on other sites More sharing options...
Redbird Posted October 26, 2009 Share Posted October 26, 2009 Different cylinder pairing, but as stated, it will mount up fine. I had a carbed Akra header on my '01. In that case there was some interference with the lower radiator mount. You might run into similar issues depending on the make of your aftermarket header. Nothing you can't work around with a little ingenuity, but be aware it might not be as simple as just swapping them straight across. Quote Link to comment Share on other sites More sharing options...
Hank.SD Posted October 26, 2009 Author Share Posted October 26, 2009 Very cool. Thanks everyone for the fast responses! Quote Link to comment Share on other sites More sharing options...
lexxus Posted October 27, 2009 Share Posted October 27, 2009 The lower radiator mount will be a small issue. they are slightly different in lengths, so if you have them both its a easy fix. you will need the longer one i think,and the mounting hole isn't in the same place. if my memory sevres me right. i did this swap. Quote Link to comment Share on other sites More sharing options...
