Hobicus Posted September 22, 2009 Share Posted September 22, 2009 ok lemme know when you want to get er done. Hey Wade, if you are in a pinch and need one really quickly you can take the one off my bike, as it's not in use ATM (needs a fork overhaul).. and just give me the one when your order arrives. Only has a few thousand miles on it, got it from John. Let me know. Is it hard to change the CCT? I am getting conflicting reports. The dealer says 3.5-4 hours labor. That's really due to a bit of a naming issue. The actual CCT is a plate inside the engine that presses on the cam chain. I have never actually seen a documented failure of this part of the bike. What the board traditionally calls a CCT is really a "Lifter Set" that puts pressure on the actual CCT. The is the part that wears out. I have had them that last 30k miles, and some that quit in as little as 6k miles. I've probably been through close to 10 of these things between the XX's what I've owned and the miles I've ridden. Brian: Try winding up the CCT and letting it go again. Sometimes that will quiet it down for a while, IF that's the problem. I've had a similar sound happen when manually turning the CCT too tight. Quote Link to comment Share on other sites More sharing options...
John01XX Posted September 22, 2009 Share Posted September 22, 2009 I have a batch of fresh new CCT Lifter Sets to be delivered on Thursday ! They had been back ordered for 10 days Quote Link to comment Share on other sites More sharing options...
Msl217 Posted September 22, 2009 Share Posted September 22, 2009 ok lemme know when you want to get er done. Hey Wade, if you are in a pinch and need one really quickly you can take the one off my bike, as it's not in use ATM (needs a fork overhaul).. and just give me the one when your order arrives. Only has a few thousand miles on it, got it from John. Let me know. Is it hard to change the CCT? I am getting conflicting reports. The dealer says 3.5-4 hours labor. That's really due to a bit of a naming issue. The actual CCT is a plate inside the engine that presses on the cam chain. I have never actually seen a documented failure of this part of the bike. What the board traditionally calls a CCT is really a "Lifter Set" that puts pressure on the actual CCT. The is the part that wears out. I have had them that last 30k miles, and some that quit in as little as 6k miles. I've probably been through close to 10 of these things between the XX's what I've owned and the miles I've ridden. Brian: Try winding up the CCT and letting it go again. Sometimes that will quiet it down for a while, IF that's the problem. I've had a similar sound happen when manually turning the CCT too tight. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
spicholy Posted September 22, 2009 Author Share Posted September 22, 2009 Brian: Try winding up the CCT and letting it go again. Sometimes that will quiet it down for a while, IF that's the problem. I've had a similar sound happen when manually turning the CCT too tight. I adjusted the three balance shafts, and the noise seems to be gone. It came back for a moment then went away for good I hope. If it comes back, I will that a try. Quote Link to comment Share on other sites More sharing options...
