tomek Posted August 5, 2009 Share Posted August 5, 2009 Any good tricks how to remove them ?.They have not been touched in ,eh,,,,,10+ years.I`d like to check bearings before looong drive. Quote Link to comment Share on other sites More sharing options...
Skull Posted August 9, 2009 Share Posted August 9, 2009 Any good tricks how to remove them ?.They have not been touched in ,eh,,,,,10+ years.I`d like to check bearings before looong drive. Just buy new ones, and clean and repack the bearings while you're at it. Quote Link to comment Share on other sites More sharing options...
cbrxxquad Posted August 9, 2009 Share Posted August 9, 2009 man, I just can not believe this ain't a troll thread, or there is something I am missing. A screw driver between the hub and the cap roll stop around the edge and work your self around prying it up a little in each spot, if it is a stock one, If it is a bearing buddy, same but will need a sharp edge to get in between like a scraper. Kinda hard to explain, and would be easier to draw something. I have even had to use some channel locks to grab them and wiggle out. But, a question like that coming from you, not likely. Some body has kidnapped Tomek . Quote Link to comment Share on other sites More sharing options...
tomek Posted August 9, 2009 Author Share Posted August 9, 2009 man, I just can not believe this ain't a troll thread, or there is something I am missing. A screw driver between the hub and the cap roll stop around the edge and work your self around prying it up a little in each spot, if it is a stock one, If it is a bearing buddy, same but will need a sharp edge to get in between like a scraper. That method did not work,they were almost welded solid.That is way I ask the question in the first place. Anyway,I grabbed large wise grips and managed to spin caps in hubs.After that the rest was a breeze. I`m really glad I`ve checked those bearings.One inner was was totally shot,second almost done,,,,,,,and we are trailering to Montana on Friday,they would`ve never made the trip. Quote Link to comment Share on other sites More sharing options...
cbrxxquad Posted August 9, 2009 Share Posted August 9, 2009 man, I just can not believe this ain't a troll thread, or there is something I am missing. A screw driver between the hub and the cap roll stop around the edge and work your self around prying it up a little in each spot, if it is a stock one, If it is a bearing buddy, same but will need a sharp edge to get in between like a scraper. That method did not work,they were almost welded solid.That is way I ask the question in the first place. Anyway,I grabbed large wise grips and managed to spin caps in hubs.After that the rest was a breeze. I`m really glad I`ve checked those bearings.One inner was was totally shot,second almost done,,,,,,,and we are trailering to Montana on Friday,they would`ve never made the trip. great, anybody but you, well almost. Glad you got it, glad you checked it. I would have said something the first time I saw it but, just knew it was something not normal. Quote Link to comment Share on other sites More sharing options...
