dehning Posted July 26, 2009 Share Posted July 26, 2009 I'm re-assembling a '99 VFR800 I purchased in pieces a few weeks back, it's almost complete, but I have two wiring questions that I need help on. I've posted at VFR World, but nobody seems to know. The first question involves a little plug that comes up from somewhere on or near the right die of the engine, see pic 1 (and no, it's not the one that goes into the bottom or back of the airbox) The second is about the fused red line that comes directly off the positive battery terminal, the fuse has an OEM position, so I assume it's stock and the other end seems to plug into a plug on the closest point on the harness (according to the service manual). The bike turns on, turns over and things seem to work without it being connected. See pic 2 Hope somebody here can help. The third pic is what it looked like before it was torn down. Thanks Quote Link to comment Share on other sites More sharing options...
Para045 Posted July 27, 2009 Share Posted July 27, 2009 I'm re-assembling a '99 VFR800 I purchased in pieces a few weeks back, it's almost complete, but I have two wiring questions that I need help on. I've posted at VFR World, but nobody seems to know. The first question involves a little plug that comes up from somewhere on or near the right die of the engine, see pic 1 (and no, it's not the one that goes into the bottom or back of the airbox) The second is about the fused red line that comes directly off the positive battery terminal, the fuse has an OEM position, so I assume it's stock and the other end seems to plug into a plug on the closest point on the harness (according to the service manual). The bike turns on, turns over and things seem to work without it being connected. See pic 2 Hope somebody here can help. The third pic is what it looked like before it was torn down. Thanks I posted this on my local VFR site OzVFR, maybe someone there will know :icon_think: Quote Link to comment Share on other sites More sharing options...
dehning Posted July 27, 2009 Author Share Posted July 27, 2009 Thanks! I have everything else hooked up, just those two elude me. Quote Link to comment Share on other sites More sharing options...
Para045 Posted July 28, 2009 Share Posted July 28, 2009 Thanks! I have everything else hooked up, just those two elude me. Nothing on OzVFR yet, have you tried VFRDiscussion.com?, as couple of guys suggested there :icon_think: Quote Link to comment Share on other sites More sharing options...
TuffguyF4i Posted July 28, 2009 Share Posted July 28, 2009 Just an FYI (not trying to be a smart ass). Before you pull stuff apart. If its not obvious what hooks to what, mark it with a sharpie. I use diff colored paint pens and it removes guess work. Quote Link to comment Share on other sites More sharing options...
dehning Posted July 28, 2009 Author Share Posted July 28, 2009 Not to be a smart-ass back, but if you read the first line of my post it says "I'm re-assembling a '99 VFR800 I purchased in pieces" I actually got a response back from the VFR group and found the connector, now I'm just waiting for my iridium plugs and the yuasa battery before testing her out. I will warn anybody else who attempts this that after spending many hours on a Ninja 250, a CBR1000F and a VFR750, that the VFR800's plumbing is orders of magnitude more complex, even having the shop manual was only a limited help. The linked brake system wasn't as complex as I had expected (but I still have to bleed it) Will keep y'all posted. Quote Link to comment Share on other sites More sharing options...
01xxallen Posted July 28, 2009 Share Posted July 28, 2009 I actually got a response back from the VFR group and found the connector So..............................what was it? Quote Link to comment Share on other sites More sharing options...
jon haney Posted July 28, 2009 Share Posted July 28, 2009 Looks the same as the sensor plug on the back of the air box on a Bird. I think its the inlet air temp sensor. Quote Link to comment Share on other sites More sharing options...
