OMG Posted March 11, 2009 Share Posted March 11, 2009 So, a question for you who have set valves more than once. Is it better to have the clearance on the low side or high side of tolerance. I'm wondering if, with miles, the valve clearance opens up or gets tighter. Quote Link to comment Share on other sites More sharing options...
rockmeupto125 Posted March 11, 2009 Share Posted March 11, 2009 Valve clearance gets tighter. Its not the stem that wears, its the valve and the seat at the area where they contact each other. As the valve material and the valve seat material wear away, the valve sinks deeper into the seat, decreasing the clearance between the cam and the follower. If you're trying to maximize the intervals between valve adjustment, you'd set them to the greater clearance. You'll also get better torque/midrange from that setting. Quote Link to comment Share on other sites More sharing options...
