Electronic Flasher Relay
TJ1137
I was wondering if anyone has successfully used an electronic flasher in their BB. I have a 99 with an integrated taillight. It has a fast blink rate, so I bought one of these relays. It works fine for about 30-60 seconds then it gets warm and stops working. They also sent me a heavy duty one which has 3 wires instead of 2. It doesn't work at all. Both are said to be plug and play for the XX. Has anyone had this problem or know of a relay that worked??
Update: The heavy duty relay they sent me causes the tun signal fuse to blow.
I purchased the flasher from Clear Alternatives. It works great!! Only $12.95
Give them a call. You have to disconnect 1 wire, I'm not sure whcih, that is why I suggest you call them.
http://clearalternatives.com/Merchant2/mer...ry_Code=Flasher
Installation instructions
http://www.clearalternatives.com/flasher.htm
I had mini turn signals on the rear. When I put the integrated taillight on my 97, it blinked too fast. So I hooked up the inter. and the mini turn signals together and it worked right and with both the taillight and mini's blinking, you can see it a lot better.
