Emillard Posted May 18, 2008 Share Posted May 18, 2008 I bought my bird with Throttlemeisters installed. On a long ride this weekend, the throttle side end fell off some place. Since I have no idea where it is, I'm replacing the bar ends. I pulled off the clutch side and everything looked normal. However on the throttle side I have a question. WTF is this metal piece sticking out? I assume I have to remove it somehow to put new "normal" weights on it but how? Thanks in advance. BTW, I have clutch side weight for sale if someone is interested. Quote Link to comment Share on other sites More sharing options...
CxBXR Posted May 19, 2008 Share Posted May 19, 2008 Look down in side it ,should be an allen head bolt you must loosen to remove it. Quote Link to comment Share on other sites More sharing options...
Emillard Posted May 19, 2008 Author Share Posted May 19, 2008 Look down in side it ,should be an allen head bolt you must loosen to remove it. Thanks. I looked and there is no allen head bolt to remove. I'm still stuck and wondering how to get this phucker off. Quote Link to comment Share on other sites More sharing options...
Para045 Posted May 19, 2008 Share Posted May 19, 2008 Quote Link to comment Share on other sites More sharing options...
Emillard Posted May 19, 2008 Author Share Posted May 19, 2008 Not a bad idea, but not the path I want to go down yet. C'mon, someone on here has to know how to get this stupid thing off. Quote Link to comment Share on other sites More sharing options...
Emillard Posted May 19, 2008 Author Share Posted May 19, 2008 Not a bad idea, but not the path I want to go down yet. C'mon, someone on here has to know how to get this stupid thing off. Problem solved. A quick phone call to Throttlemeister set me straight. Quote Link to comment Share on other sites More sharing options...
Wockman Posted May 19, 2008 Share Posted May 19, 2008 You should be able to grab it with a big pair of vise-grips and twist and pull and it should slide out with a bit of effort... Quote Link to comment Share on other sites More sharing options...
Hobicus Posted May 20, 2008 Share Posted May 20, 2008 Send a PM off to DavesXX01 and he'll hook you up with a replacement Throttlemeister. Quote Link to comment Share on other sites More sharing options...
