BigArn Posted April 10, 2008 Share Posted April 10, 2008 High, got a 2002 XX, and need to get power up to the front of the bike for my radar detector. Bought a panel style Powerlet plug, and was going to put it in the front panel that is under the instrument cluster. Any other places that might be a better choice. Just a little concerned with clearance behind that panel, there seems to be enough, but I want to be sure before drilling a hole in it. Thanks Mark S. Quote Link to comment Share on other sites More sharing options...
RXX Posted April 10, 2008 Share Posted April 10, 2008 High, got a 2002 XX, and need to get power up to the front of the bike for my radar detector. Bought a panel style Powerlet plug, and was going to put it in the front panel that is under the instrument cluster. Any other places that might be a better choice. Just a little concerned with clearance behind that panel, there seems to be enough, but I want to be sure before drilling a hole in it. Thanks Mark S. Where are you putting the detector? If you put it on a mount, Powerlet makes the whole setup, but yeah, you still have to mount an outlet somewhere. You know you can hardwire your detector into the bike & bypass any powerlet expense entirely? Check and see, but your detector may not need anything but a 12V power source. Quote Link to comment Share on other sites More sharing options...
