clutchburningracing Posted March 9, 2008 Share Posted March 9, 2008 Time for a new project. Selling my 03 Bird that I bought new in 05, has 3300 miles started out with a turbo and motor was built around it. Sold the turbo changed over to n20 but I have not sprayed it yet. If you want a streetbike or a race bike this one will do both. Here is a short list of what it still has, and I am sure I will leave some stuff out. Motor is 1mm over, Elton did the bore and block work JE 9.0:1 forged turbo pistons Falicon rods procut trans cable clutch conversion billet fuel rail w/big injectors external fuel pump w/ 1:1 reg and gauge 2inch oil pan AirTech glass tank w/ a brand new spare never used just like it still in gel coat AirTech 10 over glass tail Trac 10 over arm w/axle adj. billet clutch basket MTC multistage lockup clutch quick access clutch cover forks cut and re-valved Fox twin clicker rear shock Brand new n2o 2.5lb bottle never filled, and system dry shot billet spray bar in the air box Schnitz window switch Schnitz 2 dial progressive controller pcIII and a pcII for the timing co2 air shifter and a boat load of other stuff that will go with it the motor pulled 140hp in Feb. I have not sprayed it yet because the clutch was set up for the turbo. I have ordered some softer springs and will continue to test and tune on it. The new CBR1000RR will be out later this month and my budget (wife) will not allow me to get anything else until the Bird finds a new home. I built this thing strong! if you have access to a turbo you can make big power with this solid foundation. Or if you just want to bracket race on sunday and drive it to work on monday, this is your machine! I am asking $7500 for everything, that is a very cheap price for what I have spent trying to get it this way. (The rods, pistons, and trans cost me $2000) if you have any questions give me a shout. Thanx Quote Link to comment Share on other sites More sharing options...
clutchburningracing Posted March 17, 2008 Author Share Posted March 17, 2008 $7000 needs to go! Quote Link to comment Share on other sites More sharing options...
