01xxallen Posted November 22, 2007 Share Posted November 22, 2007 I heard this a while back and I can't believe how well it works. When installing new grips, it's difficult to slide them on. I had a fitting for my air compressor for pumping up basketballs, footballs, you know, the needle thing. Slide it under the new grip, let the air flow, and the grip rides on a cushion of air onto the bar. Magic. Quote Link to comment Share on other sites More sharing options...
SLyFoXX Posted November 22, 2007 Share Posted November 22, 2007 Very simple to do.. Try these Spider Grips Great Grips. I put on another pair, I think they were Pro Grips, changed them out once I rode a bike with the Spider Grips. Quote Link to comment Share on other sites More sharing options...
cbrxxquad Posted November 22, 2007 Share Posted November 22, 2007 A little carb cleaner, wet it and slide on, dries and sticks. to get off reverse, spray in with the little straw turn and remove. Quote Link to comment Share on other sites More sharing options...
CxBXR Posted November 22, 2007 Share Posted November 22, 2007 A little carb cleaner, wet it and slide on, dries and sticks. to get off reverse, spray in with the little straw turn and remove. Ive tried the carb cleaner trick on a dirt bike once & it melted a set of brand new rubber grips, Brand name was pro grips, It may have been cheap or NOS rubber ? I would not recomend this to anyone unless you are absolutely positive it wont melt the rubber in the process. Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted November 22, 2007 Share Posted November 22, 2007 I've heard that AquaNet or other aersol hairspray works for that grip trick. Quote Link to comment Share on other sites More sharing options...
cbrxxquad Posted November 23, 2007 Share Posted November 23, 2007 A little carb cleaner, wet it and slide on, dries and sticks. to get off reverse, spray in with the little straw turn and remove. Ive tried the carb cleaner trick on a dirt bike once & it melted a set of brand new rubber grips, Brand name was pro grips, It may have been cheap or NOS rubber ? I would not recomend this to anyone unless you are absolutely positive it wont melt the rubber in the process. Never have put that much on them, quick shot slide on, done every grip for 30 years that way, never had one slip or disolve. But I guess your results could be different. Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted November 23, 2007 Share Posted November 23, 2007 I always glue mine... I'd rather be safe than sorry. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted November 23, 2007 Share Posted November 23, 2007 I use brake cleaner, doesn't eat the grips. Quote Link to comment Share on other sites More sharing options...
Para045 Posted November 23, 2007 Share Posted November 23, 2007 I've heard that AquaNet or other aerosol hair spray works for that grip trick. Yeah I have used that aerosol hair styling mousse and the grips slide straight on, leave for 10-15 mins and then wipe with a wet towel or wash lightly and they never move Quote Link to comment Share on other sites More sharing options...
MrBadExxample Posted November 24, 2007 Share Posted November 24, 2007 1. apply rubbing alcohol to the bars 2. slide the grip on 3. blow compressed air under the grip to evaporate the alcohol It's the best method I've found. The grips are stuck for life. Quote Link to comment Share on other sites More sharing options...
JuXXtin Posted November 24, 2007 Share Posted November 24, 2007 Hairspray has worked good for my grips. Quote Link to comment Share on other sites More sharing options...
Angee Posted November 25, 2007 Share Posted November 25, 2007 soapy water works good too...it's sticky when it dries, and the grips stay on. We did that with the bird right before NEXXT. Quote Link to comment Share on other sites More sharing options...
TX1100F Posted November 26, 2007 Share Posted November 26, 2007 soapy water works good too...it's sticky when it dries, and the grips stay on. +1 Simple and effective. Compressed air takes them off like magic. My old grips were glued on with some rubber cement like stuff. They didnt even stand a chance against 90psi. Quote Link to comment Share on other sites More sharing options...
runner Posted November 26, 2007 Share Posted November 26, 2007 And another one...apply clear paint (spray-can)...and it slips on like magic and stays put once dried... Quote Link to comment Share on other sites More sharing options...
DaveK Posted November 26, 2007 Share Posted November 26, 2007 Spider Grips look great....just ordered a pair from Pit-Bull. Thanks for the grip tip ! Quote Link to comment Share on other sites More sharing options...
blkbrdrydr Posted November 28, 2007 Share Posted November 28, 2007 A little carb cleaner, wet it and slide on, dries and sticks. to get off reverse, spray in with the little straw turn and remove. Ive tried the carb cleaner trick on a dirt bike once & it melted a set of brand new rubber grips, Brand name was pro grips, It may have been cheap or NOS rubber ? I would not recomend this to anyone unless you are absolutely positive it wont melt the rubber in the process. I've used brake cleaner spray for years and it works very well on all types of grips Quote Link to comment Share on other sites More sharing options...
JuXXtin Posted November 29, 2007 Share Posted November 29, 2007 Best tip ever.... for those with big hands. :icon_shifty: Cut a 1/4" inch off each end of the old grips you're throwing away. Install them. Install the brand new grips over the old ones. Big improvement! !!!! WOW !!!! Quote Link to comment Share on other sites More sharing options...
