aseecobra Posted September 16, 2003 Share Posted September 16, 2003 Anybody know if a Sport Production system for a carb XX will physically fit a 99 up? If not, why? Thanks Quote Link to comment Share on other sites More sharing options...
PGA XX Posted September 16, 2003 Share Posted September 16, 2003 I know Jimmyz250 has a '97 w/ a full Akra sport production system, and I have the same system on my '02. There may be slight differences, but I think it's the same :?: Quote Link to comment Share on other sites More sharing options...
ncblkbrd1100xx Posted September 17, 2003 Share Posted September 17, 2003 Yes it will fit with some washers to the radiator mount, and trimming the plastic. You may have to trim the left lower a bit underneath. Biggest problem is the radiator mounting. Quote Link to comment Share on other sites More sharing options...
aseecobra Posted September 17, 2003 Author Share Posted September 17, 2003 ncblkbrd1100xx I have a X11 and the bottom of my radiator mounts to a bracket that is on the motor and comes out between the center pipes. Does the blackbird rad mount to tabs on the head pipes? PGA XX So you have the 97-98 system on your 02? I asked Akra this question and received a response that didn't explain in detail: Dear Sir, Unfortunately it will not fit, because the header tube assemblys and the linkpipes are different. Best regards, Ales Hrovatin AKRAPOVIC Exhaust System Technology tel: +386 1 7878 404 fax: + 386 1 7878 405 -----Izvorno sporočilo----- Od: Chris [mailto:robbyrubber@excite.com] Poslano: 15. september 2003 20:46 Za: tehinfo Zadeva: RE: CBR1100XX sport production Dear Ales, Thank you for the help. I have one more question. Can a CBR1100XX Sport production system for 96-98 work on a 99-03 ? What is the difference? Does the later model have a o2 sensor mount? Thank you, Chris Quote Link to comment Share on other sites More sharing options...
ncblkbrd1100xx Posted September 17, 2003 Share Posted September 17, 2003 That reply is correct, they are different. But, many places here in the states carry only the earlier version and sell it as a one size fits all..without the owners the any wiser. The radiator mounts on a bracket on the head which you will need to space out, also the bottom link tube will hit the plastic and will require some spacers under the left lower. I have the correct system on a 99 and it also needs these....there isn't a bunch of difference..if you are buying new...get the correct one...used and a good price.....try it and see what you think..... Quote Link to comment Share on other sites More sharing options...
