John01XX Posted November 7, 2006 Share Posted November 7, 2006 Hey gumbo do you think the horn would work there with a PCIII installed in the tail section also? I might order me one and go ahead and see about mounting it up front like John. Thanks for the pics. Diffenently mount it up front where it is suppose to be. Plus it is so loud that under your seat may give a sensation that will cause a problem for your Butt while riding !! Remove OEM horn and spring steel bracket and mount new 1" "L" bracket with 2" bolt through hole in frame just above the old bracket, wire up and done. Be prepared before pressing the button........It is LLLOOOOOUUUUUUDDDDDDD ! Quote Link to comment Share on other sites More sharing options...
HERBXX Posted November 7, 2006 Share Posted November 7, 2006 Hi John, would it be possible to get a picture or the mounting position. Are you mounting it to the fairing stay.? I have a hid ballast up in there as well and i am wondering if have room for both. Is it the compact air horn u guys are using ? Do you have a model name or number ? Thanks Herb Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted November 7, 2006 Share Posted November 7, 2006 Here's where I got mine. http://erston.com/stebel.htm I'm also surprised you mounted it in the stock location, doesn't it hit the fender on hard braking? That thing is so loud it doesn't matter where you mount it. Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted November 7, 2006 Share Posted November 7, 2006 Thanks for the tip John, if you can snap a picture I would greatly appreciate it. What kinda sound does it ring? train? oldsmobile? cruiseliner? Peterbilt? Quote Link to comment Share on other sites More sharing options...
HERBXX Posted November 7, 2006 Share Posted November 7, 2006 Just orderd one, slick website. If i cant fit on the bird i'll put it on the silverado. Quote Link to comment Share on other sites More sharing options...
bartonmd Posted November 7, 2006 Share Posted November 7, 2006 Here's where I got mine. http://erston.com/stebel.htm I'm also surprised you mounted it in the stock location, doesn't it hit the fender on hard braking? That thing is so loud it doesn't matter where you mount it. I looked at it with my bike ('97) and it looked as if it would/could rub on the oil cooler... and John's oil cooler is lower, with his being an FI bike... Mike Quote Link to comment Share on other sites More sharing options...
John01XX Posted November 7, 2006 Share Posted November 7, 2006 Here's where I got mine. http://erston.com/stebel.htm I'm also surprised you mounted it in the stock location, doesn't it hit the fender on hard braking? That thing is so loud it doesn't matter where you mount it. I looked at it with my bike ('97) and it looked as if it would/could rub on the oil cooler... and John's oil cooler is lower, with his being an FI bike... Mike I will have to see if I can get a Picture for you but yes it is the Stebel Compact Nautilus Horn. I have two HID starters and transformers mounted to the fairing stay and also the control box for my M20 Blinder Laser Jammer and of course now the Horn as well, all tucked in neatly out of sight. The horn is attached to the point where the fairing stay meets the goose neck. There was a 1/2" hole empty at the junction there that I put a 1/2" X 2" bolt through to attach the "L" bracket to mount the horn to. It is placed a couple inches higher than the original horn mount since the stebel is longer and I needed to keep it high enough to clear the fender under front end heavy loading. It ended up hanging down just right so that you can not see it. It is just barely above the bottom of the nose plastics. Hope that helps. I will have a problem getting a decent picture before the weekend due to it being dark by the time I get home. It is raining every day now so I have been caging it to work this week. Quote Link to comment Share on other sites More sharing options...
bartonmd Posted November 7, 2006 Share Posted November 7, 2006 Here's where I got mine. http://erston.com/stebel.htm I'm also surprised you mounted it in the stock location, doesn't it hit the fender on hard braking? That thing is so loud it doesn't matter where you mount it. I looked at it with my bike ('97) and it looked as if it would/could rub on the oil cooler... and John's oil cooler is lower, with his being an FI bike... Mike I will have to see if I can get a Picture for you but yes it is the Stebel Compact Nautilus Horn. I have two HID starters and transformers mounted to the fairing stay and also the control box for my M20 Blinder Laser Jammer and of course now the Horn as well, all tucked in neatly out of sight. The horn is attached to the point where the fairing stay meets the goose neck. There was a 1/2" hole empty at the junction there that I put a 1/2" X 2" bolt through to attach the "L" bracket to mount the horn to. It is placed a couple inches higher than the original horn mount since the stebel is longer and I needed to keep it high enough to clear the fender under front end heavy loading. It ended up hanging down just right so that you can not see it. It is just barely above the bottom of the nose plastics. Hope that helps. I will have a problem getting a decent picture before the weekend due to it being dark by the time I get home. It is raining every day now so I have been caging it to work this week. Wow... is the horn mounted in a different spot on the later models than the earlier (carb'd) models?? My factory horn location is on the lower tripple clamp... Mike Quote Link to comment Share on other sites More sharing options...
John01XX Posted November 7, 2006 Share Posted November 7, 2006 MIke You are correct the OEM is mounted to the center of the triple tree. The Stebel is mounted just above the old place and does not move. I had to grab it and bend the horn mount slightly so that the forks did not touch it when moved lock to lock Quote Link to comment Share on other sites More sharing options...
blkbrdrydr Posted November 10, 2006 Share Posted November 10, 2006 I just installed one myself, GREAT HORN! I put it under the gas tank mounted against the frame where the shock mounts. (If you look in the manual it's where the evap can goes if you have a Cali. bike.) How did you mount the horn against the frame? Got any photos?? Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted November 10, 2006 Share Posted November 10, 2006 I just installed one myself, GREAT HORN! I put it under the gas tank mounted against the frame where the shock mounts. (If you look in the manual it's where the evap can goes if you have a Cali. bike.) How did you mount the horn against the frame? Got any photos?? Hose clamp, works great. I was going to drill and tap a hole in the frame but this was easier. Quote Link to comment Share on other sites More sharing options...
blkbrdrydr Posted November 23, 2006 Share Posted November 23, 2006 The horn is attached to the point where the fairing stay meets the goose neck. There was a 1/2" hole empty at the junction there that I put a 1/2" X 2" bolt through to attach the "L" bracket to mount the horn to. It is placed a couple inches higher than the original horn mount since the stebel is longer and I needed to keep it high enough to clear the fender under front end heavy loading. It ended up hanging down just right so that you can not see it. It is just barely above the bottom of the nose plastics. I keep reading that these horns need to be mounted in a fairly vertical position. Did the "L" bracket allow the horn to be in that vertical position? Quote Link to comment Share on other sites More sharing options...
John01XX Posted November 24, 2006 Share Posted November 24, 2006 The horn is attached to the point where the fairing stay meets the goose neck. There was a 1/2" hole empty at the junction there that I put a 1/2" X 2" bolt through to attach the "L" bracket to mount the horn to. It is placed a couple inches higher than the original horn mount since the stebel is longer and I needed to keep it high enough to clear the fender under front end heavy loading. It ended up hanging down just right so that you can not see it. It is just barely above the bottom of the nose plastics. I keep reading that these horns need to be mounted in a fairly vertical position. Did the "L" bracket allow the horn to be in that vertical position? Sent you a PM Bill but to answer your question........Yes Quote Link to comment Share on other sites More sharing options...
RXX Posted May 3, 2008 Share Posted May 3, 2008 Just finished installing mine..... Yes SIR that's a loud damn horn!! Quote Link to comment Share on other sites More sharing options...
beondwacko Posted May 4, 2008 Share Posted May 4, 2008 I have done too much friggin' work to John's bike !! The Laser Jammer, the horn, the rear shock, something with the radar and the audio system, and I forget what the hell else I've done. Oh, the kill switch lanyard too. It took an old thread for my memory to jog with that subject. Quote Link to comment Share on other sites More sharing options...
John01XX Posted May 4, 2008 Share Posted May 4, 2008 I have done too much friggin' work to John's bike !! The Laser Jammer, the horn, the rear shock, something with the radar and the audio system, and I forget what the hell else I've done. Oh, the kill switch lanyard too. It took an old thread for my memory to jog with that subject. Are you BITCH'N or BRAG'N Don't forget the 550 Zumo GPS You didn't do the radar or the Audio system but did add the Buss Bar to tidy things up ! :-) Quote Link to comment Share on other sites More sharing options...
Mikey Posted August 1, 2008 Share Posted August 1, 2008 So, for the older carb'd models, how are they being mounted? I got lost when someone mentioned the hose clamp. Do we have pics or any other visual queues you guys can help with? John, what did you put in that PM (you secretive fella you). Quote Link to comment Share on other sites More sharing options...
kiwimack Posted August 1, 2008 Share Posted August 1, 2008 So, for the older carb'd models, how are they being mounted? I got lost when someone mentioned the hose clamp. Do we have pics or any other visual queues you guys can help with? John, what did you put in that PM (you secretive fella you). Mikey, The best place for the carbie birds is under the tank...............see pete from pas pix earlier this thread. cheers Quote Link to comment Share on other sites More sharing options...
