h2o player Posted October 30, 2006 Share Posted October 30, 2006 I noticed that the shop manual tells you that if you pull the front calibers (like when you change the tires) to replace the pivot and caliber mounting bolts. I have swaped several sets of tires and never had an issue. Any thoughts? Quote Link to comment Share on other sites More sharing options...
99Birdman Posted October 30, 2006 Share Posted October 30, 2006 Could be wrong but, I believe that's because the factory bolts come with a locking compund on the threads which they want you to have. Just add a little blue Loctite and you'll be fine. At least it's worked for me through several remove and replace the last couple of years. Quote Link to comment Share on other sites More sharing options...
02XXCA Posted October 30, 2006 Share Posted October 30, 2006 I stripped one of the bolts the first time I tried to remove the caliper. Have never used locktite on the replaced ones but check the torque on them periodically. Quote Link to comment Share on other sites More sharing options...
sokanxx Posted October 30, 2006 Share Posted October 30, 2006 I did loose one of the bolts on the left hand side. I didnt loctite it when I put it back on. and never I checked the torque. It took about 5000 miles for it to wiggle loose, so I would probibly recommend some loctite Quote Link to comment Share on other sites More sharing options...
beondwacko Posted October 30, 2006 Share Posted October 30, 2006 I had to pull a couple of those bolts as well when I installed the front end strap too. They were pretty tight going out as I remember. I cleaned the threads ( with a small wire brush ) and Locktite'd them back in with a moderate amout of torque. They haven't moved since. Locktite is a nice little bit of insurance unless you own a Hardley. Then it's manditory. :icon_clap: Quote Link to comment Share on other sites More sharing options...
tomek Posted October 30, 2006 Share Posted October 30, 2006 Locktite it,I`ve lost one. Quote Link to comment Share on other sites More sharing options...
tomek Posted October 30, 2006 Share Posted October 30, 2006 Locktite is a nice little bit of insurance unless you own a Hardley. Then it's manditory. :icon_clap: Hardley?? Gotta safety wire everything,Locktite won`t do,,,,,,,,,,,,, Quote Link to comment Share on other sites More sharing options...
Hobicus Posted October 30, 2006 Share Posted October 30, 2006 +1 on the Loctite. Proper torque spec should do it... but it's brakes, and I like insurance. I lost one... http://www.cbr1100xx.org/forums/index.php?showtopic=9743 And had an interesting find afterwards: http://www.cbr1100xx.org/forums/index.php?showtopic=10235 Quote Link to comment Share on other sites More sharing options...
