Zero Knievel Posted May 29, 2006 Share Posted May 29, 2006 On my 1999 Blackbird, I went to change the sprockets for the new chain coming in. When I got the front sprocket off, I was surprised to find a length of rubber hose BEHIND the sprocket coiled around the inside (between sprocket/chain and gearbox). I don't know if this got pulled in somehow (from where I am afraid to ask) or if this is some modification done to protect or reduce noise. Anyone heard of this being done? I've ridding the bike 1,000 or so miles with no performance issues. I've done a forum search, so I've not found any prior threads discussing this. Thanks. Quote Link to comment Share on other sites More sharing options...
Redbird Posted May 29, 2006 Share Posted May 29, 2006 There's a vent hose that terminates in that general area. Someone probably routed it wrong at some point resulting in it getting pulled into where you found it. Can't recall specifically what it vents off the top of my head, but I'd suggest checking the manual an replacing it, problem solved. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted May 30, 2006 Author Share Posted May 30, 2006 Well, the hose DOES fit onto the drain plug of the battery carrier. It seems too long for that purpose, but I see nothing else in the area that it should go onto. Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted May 30, 2006 Share Posted May 30, 2006 Regardless of where it was, as Redbird said...it don't belong where you found. Of that we're certain. Quote Link to comment Share on other sites More sharing options...
Zero Knievel Posted May 31, 2006 Author Share Posted May 31, 2006 After some asking around here and elsewhere, the hose isn't some weird mod I've not heard of. My best guess is that it went to the drain spout on the battery carrier (perhaps someone can confirm there's a hose on that nub). I reattached it, cut it shorter so there was less to flop around, and zip-tied it to the brake lines so it wouldn't flop around with bouncing. Problem solved. Thanks. Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted May 31, 2006 Share Posted May 31, 2006 Here's the best depiction I can find of that situation. Quote Link to comment Share on other sites More sharing options...
Obby Posted June 1, 2006 Share Posted June 1, 2006 Here's the best depiction I can find of that situation. Not to but in... but do you know where that top hose (looks like vacuum) going over the top of the tranny in you're pic? Mine just lays around there, connected to nothing. Just didn't look right to me??? PM me if you know... I think I'm hi-jacking again, but inquiring minds need to know... -Obby Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted June 1, 2006 Share Posted June 1, 2006 I'll have it apart in the next week and check it out. Quote Link to comment Share on other sites More sharing options...
Obby Posted June 1, 2006 Share Posted June 1, 2006 I'll have it apart in the next week and check it out. Quote Link to comment Share on other sites More sharing options...
