Mikesblackbird Posted May 22, 2006 Share Posted May 22, 2006 I have a 2000 mile +/- trip coming up in 2 weeks and I want to be able to power my iQue GPS/MP3, etc. On my last bike I had installed a Wally World outlet and tapped into the spare leads under the headlight. Is there a spot on the BB that I can tap into and add an outlet plug? I also want a liitle better quality than what Walmart has to offer, but don't want to step up to the higher end Powerlet brands. Is there something that is more affordable? I also plan to have the access point on the left side of the gas tank in the fairing panel. Is that a good spot? Thanks. Quote Link to comment Share on other sites More sharing options...
willxx23 Posted May 22, 2006 Share Posted May 22, 2006 I have a 2000 mile +/- trip coming up in 2 weeks and I want to be able to power my iQue GPS/MP3, etc. On my last bike I had installed a Wally World outlet and tapped into the spare leads under the headlight. Is there a spot on the BB that I can tap into and add an outlet plug? I also want a liitle better quality than what Walmart has to offer, but don't want to step up to the higher end Powerlet brands. Is there something that is more affordable? I also plan to have the access point on the left side of the gas tank in the fairing panel. Is that a good spot? Thanks. Thats a very good location. I bought a cheap one from Radio Shack and spliced it in under my seat, nothing fancy but works great and comes in very handy. Quote Link to comment Share on other sites More sharing options...
SLY DVL Posted May 22, 2006 Share Posted May 22, 2006 I installed one under my seat. That's where all the fuses are so it made sense. It was a semi-weather resistant one I bought from Wally Mart. It's got a spring loaded flap on it that you pry down on to plug in your accy. I just velcroed it to the plastic so I can move it around a limited amount. The power cord on my Garmin reaches quite nicely and I can roll up any excess and store it under the seat. K Quote Link to comment Share on other sites More sharing options...
Mikesblackbird Posted May 22, 2006 Author Share Posted May 22, 2006 I installed one under my seat. That's where all the fuses are so it made sense. It was a semi-weather resistant one I bought from Wally Mart. It's got a spring loaded flap on it that you pry down on to plug in your accy. I just velcroed it to the plastic so I can move it around a limited amount. The power cord on my Garmin reaches quite nicely and I can roll up any excess and store it under the seat. K Did you just connect it to the battery terminals or did you use some sort of relay? Quote Link to comment Share on other sites More sharing options...
SLY DVL Posted May 22, 2006 Share Posted May 22, 2006 If I remember correctly I spliced it into the HOT side of the fuse box (between the battery & the fuse) and then seperately fused it for 10A. I'll see if I can grab a pic this aft. and post it later today. K Quote Link to comment Share on other sites More sharing options...
lew69442 Posted May 22, 2006 Share Posted May 22, 2006 I have a 2000 mile +/- trip coming up in 2 weeks and I want to be able to power my iQue GPS/MP3, etc. On my last bike I had installed a Wally World outlet and tapped into the spare leads under the headlight. Is there a spot on the BB that I can tap into and add an outlet plug? I also want a liitle better quality than what Walmart has to offer, but don't want to step up to the higher end Powerlet brands. Is there something that is more affordable? I also plan to have the access point on the left side of the gas tank in the fairing panel. Is that a good spot? Thanks. Westmarine is a good source. There you will find marine grade electrical parts which in turn will have either tinned or nickle plated contacts. Here is a under the seat pic.......... Quote Link to comment Share on other sites More sharing options...
dennis Posted May 22, 2006 Share Posted May 22, 2006 I know you said you did'nt want to spend big $ on powerlet products but in my experience a lighter type outlet is susceptible to vibration- contact problems and corrosion.Just for reference check the site of easternbeaver.com. I have one of his dual/switched relay kits and they are slick. Do a search and you can find all kinds of fuse blocks and accessory outlet set-ups. Quote Link to comment Share on other sites More sharing options...
