panote Posted April 5, 2006 Share Posted April 5, 2006 My country will stop distribute octane 95 in the end of the year.Can black bird use the gasoline octane 91 ? Quote Link to comment Share on other sites More sharing options...
K9XX Posted April 5, 2006 Share Posted April 5, 2006 87 is fine too 91 is the highest we can get where I am. I run 91 to keep the combustion chanbers clean, but she runs fine on 87 as well. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted April 5, 2006 Share Posted April 5, 2006 Is octane rated the same in all countries? Quote Link to comment Share on other sites More sharing options...
Justin Posted April 5, 2006 Share Posted April 5, 2006 No worries ... the XX has a very good knock sensor ... run 87 and you will be fine .. if it does knock, go up to 89 or 91. I think the recomended fuel for the XX is 91 RON which is research octane measure, that equals @ 87 pump octane. Quote Link to comment Share on other sites More sharing options...
Obby Posted April 5, 2006 Share Posted April 5, 2006 My country will stop distribute octane 95 in the end of the year.Can black bird use the gasoline octane 91 ? I'm not sure which year your bird is, but from my experience 87 octane gas on a '97 bird caused a pinging with load. 91 octane, no problems. Quote Link to comment Share on other sites More sharing options...
bajjer9 Posted April 5, 2006 Share Posted April 5, 2006 My country will stop distribute octane 95 in the end of the year.Can black bird use the gasoline octane 91 ? I'm not sure which year your bird is, but from my experience 87 octane gas on a '97 bird caused a pinging with load. 91 octane, no problems. hm must be kalifornia gas cuz 87 is all i ever run...and even the cheap stuff doesnt ping at all..ever...mine is 97 by the way...oh and mine works in the rain.. Quote Link to comment Share on other sites More sharing options...
Red J Posted April 5, 2006 Share Posted April 5, 2006 My country will stop distribute octane 95 in the end of the year.Can black bird use the gasoline octane 91 ? What country? The 97 (because that's what I have) lists 91 RON, which usually corresponds to 87 (R+M/2). You should be fine with 91 RON. J. Quote Link to comment Share on other sites More sharing options...
Elefant Posted April 5, 2006 Share Posted April 5, 2006 Is octane rated the same in all countries? Nope! Same gas may have different "octane" depending on where you are and the method used to determine "octanage". Quote Link to comment Share on other sites More sharing options...
panote Posted April 12, 2006 Author Share Posted April 12, 2006 I live in Thailand and my bird year 98. Another question, the bird year 97-98 have a " knock sensor " or not ? Thank you!! Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted April 12, 2006 Share Posted April 12, 2006 I live in Thailand and my bird year 98. Another question, the bird year 97-98 have a " knock sensor " or not ? Thank you!! If I'm not mistaken they all do. Quote Link to comment Share on other sites More sharing options...
ios1176 Posted April 12, 2006 Share Posted April 12, 2006 I started with 96 octane and that was OK. Recently I switched to 98 octane and ....what a difference.Smooth as a silk and goes like a rocket. So yeah... Quote Link to comment Share on other sites More sharing options...
MikeXX Posted April 12, 2006 Share Posted April 12, 2006 Ya'll know what the octane rating is right? http://auto.howstuffworks.com/question90.htm If it's not knocking you're not going to get any more "power" out of higher octane rated fuel. The lowest that works is the most efficient. Quote Link to comment Share on other sites More sharing options...
Red J Posted April 12, 2006 Share Posted April 12, 2006 I live in Thailand and my bird year 98. Another question, the bird year 97-98 have a " knock sensor " or not ? Thank you!! If I'm not mistaken they all do. I never unbolted a knock sensor off my 97 when I disassembled the motor. At least, not to the best of my knowledge. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted April 12, 2006 Share Posted April 12, 2006 The lowest that works is the most efficient. Is there any scientific data that I could read on this? Quote Link to comment Share on other sites More sharing options...
MikeXX Posted April 12, 2006 Share Posted April 12, 2006 The lowest that works is the most efficient. Is there any scientific data that I could read on this? http://www.ftc.gov/bcp/conline/pubs/autos/octane.htm By "efficient" here I mean financially efficient, given there's no benefit from putting 98 in your vehicle if 90 isn't knocking. Quote Link to comment Share on other sites More sharing options...
86gn Posted April 12, 2006 Share Posted April 12, 2006 To put it simply. Higher octane fuel has a higher point of ignition. It doesn't burn as easily as lower octane fuel. If you use it and don't need it you will just carbon up your engine. Quote Link to comment Share on other sites More sharing options...
