silverbird1100 Posted April 4, 2006 Share Posted April 4, 2006 I've currently got mine 47mm (from the clamp, dropped 8mm) and it seems like if I go any further, the fender is going to make contact with the bike. Not sure, but how much can you drop it and not have clearance problems? Quote Link to comment Share on other sites More sharing options...
Warchild Posted April 4, 2006 Share Posted April 4, 2006 Don't lower the front. Raise the rear instead. This ASSumes that you are after quicker steering here... if it's an issue that you are inseamed-challenged dude looking to reach the ground at stoplights, that's a different story, obviously. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted April 5, 2006 Share Posted April 5, 2006 I know that you can go one inch. Quote Link to comment Share on other sites More sharing options...
Obby Posted April 5, 2006 Share Posted April 5, 2006 I know that you can go one inch. Same here. I'm down an inch and change on my '97. Steering is perhaps too quick. Quote Link to comment Share on other sites More sharing options...
silverbird1100 Posted May 9, 2006 Author Share Posted May 9, 2006 I know that you can go one inch. I just need to go 1/2 inch. It just looks like the cables and other things are going to get smashed. Higher is only better for expert riders. When ground clearance in not an issue, lower is better Quote Link to comment Share on other sites More sharing options...
sokanxx Posted May 10, 2006 Share Posted May 10, 2006 This topic has been well hashed over check it out at this link: http://www.cbr1100xx.org/forums/index.php?...hl=drop+it+like Quote Link to comment Share on other sites More sharing options...
silverbird1100 Posted May 14, 2006 Author Share Posted May 14, 2006 Dropped mine 8mm and now there's 4.7mm from the fork seal to the clamp. How in the world are you guys dropping them that much? Quote Link to comment Share on other sites More sharing options...
Skull Posted May 15, 2006 Share Posted May 15, 2006 Dropped mine 8mm and now there's 4.7mm from the fork seal to the clamp. How in the world are you guys dropping them that much? Something is wrong with your forks. Quote Link to comment Share on other sites More sharing options...
blackhawkxx Posted May 15, 2006 Share Posted May 15, 2006 4.7mm from the fork seal to the clamp Are you sure that you are not looking at the rock guard part and not the dust seal? Quote Link to comment Share on other sites More sharing options...
silverbird1100 Posted May 16, 2006 Author Share Posted May 16, 2006 4.7mm from the fork seal to the clamp Are you sure that you are not looking at the rock guard part and not the dust seal? My bad, 4.7inches to the dust seal. You guys dropping them that much must not be using that much travel. Quote Link to comment Share on other sites More sharing options...
