RXX Posted March 25, 2006 Share Posted March 25, 2006 Hey, Duane.... when you put your bulb in, did you use that little foam donut to stabilize it or did you use something else? My bulb seems less stable in the socket than the other bulb. I mean it is OK, just not as rock solid as the other one. Also, the big rubber boot does not fit as well. Am I missing anything here? BTW, I routed the power through a rocker switch so I can power it down. Didn't want to wait ona "euro" switch. Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted March 25, 2006 Share Posted March 25, 2006 Sticking my nose in. First used an automotive kit in 2003 to try this out. I used the spongy gizmo, but was concerned about instability of the bulb. It never was an issue. The beam didn't even jiggle after hard bumps. Quote Link to comment Share on other sites More sharing options...
Warchild Posted March 25, 2006 Share Posted March 25, 2006 What I did was simply take up the excess space with a gasket from a garden hose: Then, after your test fitment determines one gasket isn't enough , you add a second gasket: Now when you install the bulb and hook up the retaining latch, these bulbs remain rock-solid in their housings. See how the circular gromment the wires pass through make for an absolutely perfect seal with the OEM rubber boot: Here both HID bulbs have just been installed. You also see the ballast for my low-beam, which resides just above the horizontal knob for headlight adjustment: To place the high-beam ballast, I used the open space behind the instrument panel at the base of the fairing mount (where it forms a natural 'Y'), and zip-tied both the ballast and the ignitor directly to the fairing mount. This was an excellent placement; the zip-ties (see 4 yellow arrows) made for another rock-solid mounting job: Quote Link to comment Share on other sites More sharing options...
RXX Posted March 25, 2006 Author Share Posted March 25, 2006 Hey, no problem sticking your nose in....great answers, all of 'em. I think I will get those hose gaskets & put them on before I get the nose bolted on Quote Link to comment Share on other sites More sharing options...
Flitemdic Posted March 25, 2006 Share Posted March 25, 2006 Yeah. What they said. Actually, I'm book marking this. I just got the nose off, and am putting this together this weekend to send out for paint on Monday, so this was an absolute perfect time for this. Thanks, guys. Duane Quote Link to comment Share on other sites More sharing options...
