arcticflipper Posted November 10, 2005 Share Posted November 10, 2005 I know that you can trace the chip that is / was used in your XX key if you have lost it, Is it possible to do the same with a 600 CBR F4? Any help will be appreciated. HISS ignition - have to replace ECU, Ignition, Tanklock, Seatlock...... Quote Link to comment Share on other sites More sharing options...
redxxrdr Posted November 10, 2005 Share Posted November 10, 2005 My O1 xx doesn't have a chip. Had keys made from the origional. Stealer had written the key code in the owners manual of both new Honda's I purchased. Just in case. If the F4 doesn't have a chip, then a good locksmith should be able to make you a replacement key. Quote Link to comment Share on other sites More sharing options...
birdie_xx Posted November 10, 2005 Share Posted November 10, 2005 Bikes in US have no HISS feature.... Quote Link to comment Share on other sites More sharing options...
indy500 Posted November 11, 2005 Share Posted November 11, 2005 If it doesn't have the HISS ign. You can go to any locksmith to have keys made. The key code is printed on the back of every lock. They can pick open the gas cap to see the code or take off the helmet lock to see the code. This process should'nt take long any is not expensive( unless you go to a rip off artist). Brian (locksmith in Indianapolis) Quote Link to comment Share on other sites More sharing options...
