The Laundry...
EVLXX
...just got easier!
They dropped off our new Kenmore Elite HE4t units yesterday...
The Washer...
· Innovation on every level, from contemporary design to energy-efficiency to unmatched cleaning performance.
· America's Largest Usable Cleaning Capacity* allows customers to wash up to 22 bath towels in one load or only one shirt and still experience the same high efficiency and safe high performance cleaning.
· America's Best Soil and Stain Removal** features a wash motion that separates clothes as they tumble so that every fiber receives uniform cleaning and rinsing.
· Energy Star® qualified: uses 68 percent less water and 67 percent less energy than conventional washers.***
· High spin speeds extract more moisture per wash load, resulting in less drying time and energy savings. 13,000 RPM's
· SensorSmart™ technology makes doing the laundry easier with nine preset cycle settings for optimal fabric care with minimal effort.
· An optional 13-inch pedestal minimizes bending and stooping, and contains a convenient drawer for all your laundry products.
* among leading brand front loading washers based on a 20 lb. load
** among leading brand front loading washers based on a 13 lb. load
*** based on the use of 42.4 gallons in a conventional washer's normal cycle
The Dryer...
· Equal in height and depth to the HE4t washer, the dryer offers sleek European styling with rounded corners, push button controls, and a smoke-tinted glass door.
· The first leading brand dryer for residential use with a see-through window.
· The impressive 7 cu.ft. drum mirrors the capacity of the HE4t washer, holding up to 22 towels in one load.
· EvenHeat™ uses moisture sensors to determine the dampness in fabrics while Automatic Temperature Control adjusts the temperature as the load dries, allowing you to safely dry delicate fabrics without worry.
· SensorSmart™ controls eliminate guesswork with nine factory preset cycles featuring the optimal time and temperature settings for the type of fabric selected.
· Ultra Quiet Pak™ provides maximum sound insulation.
The wife is actually excited about doing the Laundry....... for now anyways.
  • 2 weeks later...
But make sure you have room for them.. they run 4-5" deeper than a standard washer and dryer
We have a very small Laundry / Furnace / Hot Water heater room... so We / I bought the stackable set...
Much better Now.
My water rates have doubled in the last 5 years or so with no end in sight... so at least this is going to help.
Nice. The wife has been wanting something similar for quite a while. You should get at least a couple of really good hummers out of that deal. :D
So far they're quite cool.
Clothes are cleaner... and less loads equalls less time spent doing the laundery.
But NO Hummers yet! :?
