GriffbsXX Posted May 9, 2005 Share Posted May 9, 2005 I'm about to change the chain and sprocket on my bird. I've seen where people are going to a 16T/F and 45T/R or staying stock, but I haven't seen much about how that affects mileage. With gas prices in Mid-Cal, I'd like to go with a combo that gives me a better MPG rate. I'm getting about 35 mpg with the stock setup on the bike. Any help would be greatly appreciated. (I did search the board but didn't come up with anything solid on this) Byron Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted May 9, 2005 Share Posted May 9, 2005 Your going to get less MPG for sure. I'm not sure how much I'm getting right now but it's not good.... Quote Link to comment Share on other sites More sharing options...
GriffbsXX Posted May 9, 2005 Author Share Posted May 9, 2005 So going to a 18T/F would get better mileage? Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted May 9, 2005 Share Posted May 9, 2005 Maybe depending how you drove it, I haven't tried. But I will tell you the 16T is nice for power but I think I'm gonna do a sproket change to go back to stock. Not sure if it's the sproket or PC3 by my mileage is way down. I'm guessing around 25MPG but I've been playing a bit more than usual. Quote Link to comment Share on other sites More sharing options...
Amherst XX Posted May 10, 2005 Share Posted May 10, 2005 I am running a stock rear sprocket and a 16T front and I get about 33MPG consistantly...but I "play" alot. 8) Quote Link to comment Share on other sites More sharing options...
GriffbsXX Posted May 10, 2005 Author Share Posted May 10, 2005 I've thought about a PC for it but not sure it's worth it with a mostly stock set-up. Only thing changed is 2 bro slip-ons. Quote Link to comment Share on other sites More sharing options...
Stealth Posted May 11, 2005 Share Posted May 11, 2005 FWIW; Fuel consumption wont be effected unless you spend extended amounts of time in 6th... Quote Link to comment Share on other sites More sharing options...
K9XX Posted May 11, 2005 Share Posted May 11, 2005 I just went back to stock. I was running a 16 counter for about 18 months. I put it on because I wanted more umph. Now that I know how to ride this thing and have done some other mods, I wanted the stock rubberized countershaft back. Honestly, I can't really tell unless I am winding it up in 1st and 2nd, and even then it's not a huge difference any more. IMO. Quote Link to comment Share on other sites More sharing options...
CALCXX Posted May 20, 2005 Share Posted May 20, 2005 I tried a 16 tooth and although it does accelerate harder and lift the front wheel easier, I found it harder to ride in the 10 -30 mph twisties. The stock CS sprocket allows damn near 70mph in low gear making tight twisties perfect. Otherwise, (w/16) first is too low and second is too high. Went back to stock. Love the high speed capability with the stock gearing also. If I had more power, I would consider an even taller CS sprocket. Even thought about putting a taller gear on my 954. My .02 cents, Cal Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted May 20, 2005 Share Posted May 20, 2005 I think Honda did a good job with the gears and overall gearing. I wont be changing. Quote Link to comment Share on other sites More sharing options...
seeten1 Posted May 21, 2005 Share Posted May 21, 2005 Will the bird actually pull to the redline in 6th with a 18T front sproket??? I know for a fact it wil with the stock gear. Will the bird pull till the rev limiter in 6th with stock gearing? Quote Link to comment Share on other sites More sharing options...
demon Posted May 21, 2005 Share Posted May 21, 2005 Will the bird actually pull to the redline in 6th with a 18T front sproket??? Uuuuhhh, NO. At redline in 6th with an 18 tooth front, you're at the 200 mph mark. You'll need a bit more power to rev it out with an 18 on the front like Northman has done, and it ain't cheap is it Chris? Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted May 24, 2005 Share Posted May 24, 2005 Will the bird actually pull to the redline in 6th with a 18T front sproket??? I know for a fact it wil with the stock gear. Will the bird pull till the rev limiter in 6th with stock gearing? I know it will in a gas station on the centerstand after airing up the tire.... :shock: :oops: Quote Link to comment Share on other sites More sharing options...
cbrxxquad Posted May 24, 2005 Share Posted May 24, 2005 and just where is that post link at Joe ?????? Quote Link to comment Share on other sites More sharing options...
GriffbsXX Posted May 24, 2005 Author Share Posted May 24, 2005 I just ordered the standard sprockets and a new front tire. Thanks all for your input. Byron Quote Link to comment Share on other sites More sharing options...
