Dotetcher Posted April 19, 2005 Share Posted April 19, 2005 Looks to be a relatively easy job. This will be my first one so is there anything I should watch out for. Thanks guys. Oh yeah. Its a '97. Fastest color. Quote Link to comment Share on other sites More sharing options...
Red J Posted April 20, 2005 Share Posted April 20, 2005 Straightforward deal. You need a gasket and the stator, as well as some RTV or Hondabond sealant. 10mm socket, drive ratchet, and IIRC, 6mm hex key for the stator itself. J. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted April 20, 2005 Share Posted April 20, 2005 Hardest part of the job is getting all the old gasket off the surfaces without damaging them. I've used razor blades and scotchbrite pads, worked for me. Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted April 22, 2005 Author Share Posted April 22, 2005 Latest update. Ron Ayers sent me the wrong stator. Looks the same but the connector on the end is different. The original has a config of 2 female recepticles parallel and one perpendicular, sort of a T formation. The one that was sent has 3 parallel recepticles (lll). The stator itself seems to be the exact same dimensions as the old one. I've heard the newer stators have a higher output than the earlier ones so maybe this isn't a bad thing. So what do I do? a. send the wrong one back and get the right one. b.pick up a wiring harness off a newer bike and just use the wire for the stator and rectifier. (would this work?) c. cut the connector off the old stator and wire it to the new one. d. Hookers I'd rather go with c. if posssible. Has anyone ever done this and if so how do you figure which wire goes to which recepticle. Oh yeah. If a phone call would be easier PM me and I'll give you my cell #. Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted April 22, 2005 Author Share Posted April 22, 2005 For those that may be interested. I've installed the stator in my '97 I got from Ron Ayers. The one they sent was for the later year xx's. I spliced the connector from the old stator onto the new stator because the connections were different. I've been told by some on the Concours owners group it should work fine. So far it does!! Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted April 23, 2005 Share Posted April 23, 2005 Do the newer ones put out more juice? Quote Link to comment Share on other sites More sharing options...
Dotetcher Posted April 23, 2005 Author Share Posted April 23, 2005 Do the newer ones put out more juice? If touring 2-up is important to you, there are some key advantages to scoring a '99 or later Blackbird: aside from being fuel injected (the '97-'98 models are carbed), the later model Blackbird have a larger fuel tank capacity (6.3gal vs 5.8gal), and a larger alternator (460watts vs 390 watts) This is from a thread on the PUB. So the answer would be yes. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted April 23, 2005 Share Posted April 23, 2005 Good to know that with just a plug change I can get more juice. If mine ever craps out I'll do that. Quote Link to comment Share on other sites More sharing options...
