mbarr78 Posted February 7, 2005 Share Posted February 7, 2005 I just purchased the NEP and have some install Q's. Looks to be very simple but wanted to make sure that trimming the tab down to fit between the cables was what everyone here has done. This may be a stupid question but I can't get to the main site where it showed the install of the NEP. With the site down is there anyway to access the site mabey I just don't have the correct address. Please excuse my ignorance. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted February 7, 2005 Share Posted February 7, 2005 As far as I know you can't access the main site. There was a great write up on installing it. What I did was use the hole already in the bottom of the switch housing. I drilled a hole in the foot of the NEP and threaded a machine screw (blunt tip) into it. this lines up with the hole in the switch housing and just rides inside it. Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted February 8, 2005 Share Posted February 8, 2005 I roughed up the housing where the NEP would mount and epoxed it to the switch housing. Found I could get it in a better position that way. 18,000K and it's still working great.... Quote Link to comment Share on other sites More sharing options...
willxx23 Posted February 8, 2005 Share Posted February 8, 2005 I used double sided tape the thick one and cut two small squares of it and attached it to the flat area underneath the housing, it lasts about a year and then I redo it. Quote Link to comment Share on other sites More sharing options...
