camell0ndosequis Posted May 16, 2003 Share Posted May 16, 2003 Ok, fellas ... I'm having a problem with this seemingly easy screw out plug. The previous installer must of gotten the threads crossed, cuz that f'er ain't coming out. once the screwdriver slipped (and being the soft alum that it is) it started to strip. i broke out the wd-40 and let it soak a bit, hoping it would solve the problem. wrong! so now it's all f'd up! and i'm running out of options. any of ya'll got any advice? thanks... Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted May 16, 2003 Share Posted May 16, 2003 Those new stripped screw removers from Sears. Never used them but look good on the comercials. :???: Quote Link to comment Share on other sites More sharing options...
Andy1100 Posted May 16, 2003 Share Posted May 16, 2003 I'm assuming its a straight slot screw you're referring to? If it's bad see if you can use a dremel and cut a new slot perpendicular, so you now have an x. Then you can start over and strip that one too! :grin: Use an impact driver on this one.....if possible. Quote Link to comment Share on other sites More sharing options...
