7 days till NEXXT, I don't need this agravation
Dion
Ride to work today and on the last little stretch do my usual roll-on to 11 o'Clock on the speedo and WTF, FI light. It stays on. I get to work, leave it running, kickstand down and I get the MAP error code(2 flashes).
Shut it down, restart and no error.
Here's to hoping it's just a vacuum line problem.
You might run through the MAP checks in the manual. If everything checks out OK, reset your ECU to clear the error codes.
I had an intermittent FI light problem I traced to an IAT code. I've had no problems since I did the diagnostics and reset the ECU.
Well you could always ride bitch with me!!!! :poke: :lol:
Ken
Bad connection/ground is the usual suspect - remove the seat and wiggle the wires, even back by the tail-light. And, if you have any after-market accessories, check those connections first.
Thanks guys.
I don't know if this is the ground issue or not, It looked like a valid code and not the flickering some have described. Didn't happen on the way home or this morning. I'll probably clear the code and once I get the tank run down check th MAP sensor as well as look at the shape of the connectors.
Ken
Thanks Ken, But you ride to fast, I'd be scared :wink:
So, Dion, are you a happy-camper-rider yet?
To be honest I'm a lazy fuck and haven't gotten around to it yet. Been to busy scrubin the new rear and just ridin. Finally stopped refilling the tank yesterday so I'll take look today.
