Dion Posted September 2, 2004 Share Posted September 2, 2004 Ride to work today and on the last little stretch do my usual roll-on to 11 o'Clock on the speedo and WTF, FI light. It stays on. I get to work, leave it running, kickstand down and I get the MAP error code(2 flashes). Shut it down, restart and no error. Here's to hoping it's just a vacuum line problem. Quote Link to comment Share on other sites More sharing options...
XXTi Posted September 2, 2004 Share Posted September 2, 2004 You might run through the MAP checks in the manual. If everything checks out OK, reset your ECU to clear the error codes. I had an intermittent FI light problem I traced to an IAT code. I've had no problems since I did the diagnostics and reset the ECU. Quote Link to comment Share on other sites More sharing options...
CBRXX Posted September 2, 2004 Share Posted September 2, 2004 Didn't someone else trace an intermittent FI light problem to a bad ground?? There is a large bundle of ground wires at one point on the frame. Was it in front of the battery under the tank?? Steve Quote Link to comment Share on other sites More sharing options...
Hookman49 Posted September 2, 2004 Share Posted September 2, 2004 Ride to work today and on the last little stretch do my usual roll-on to 11 o'Clock on the speedo and WTF, FI light. It stays on. I get to work, leave it running, kickstand down and I get the MAP error code(2 flashes).Shut it down, restart and no error. Here's to hoping it's just a vacuum line problem. Well you could always ride bitch with me!!!! :poke: Ken Quote Link to comment Share on other sites More sharing options...
speedygeezer Posted September 2, 2004 Share Posted September 2, 2004 Bad connection/ground is the usual suspect - remove the seat and wiggle the wires, even back by the tail-light. And, if you have any after-market accessories, check those connections first. Quote Link to comment Share on other sites More sharing options...
John01XX Posted September 3, 2004 Share Posted September 3, 2004 My 01 Bird had an intermittant FI light that was the one that Honda traced to a bad ground under the tank. Cleaned ground and some dialectric grease about a year ago and haven't seen it since. Quote Link to comment Share on other sites More sharing options...
Dion Posted September 3, 2004 Author Share Posted September 3, 2004 Thanks guys. I don't know if this is the ground issue or not, It looked like a valid code and not the flickering some have described. Didn't happen on the way home or this morning. I'll probably clear the code and once I get the tank run down check th MAP sensor as well as look at the shape of the connectors. Well you could always ride bitch with me!!!! Ken Thanks Ken, But you ride to fast, I'd be scared :wink: Quote Link to comment Share on other sites More sharing options...
Phalanx7.62 Posted September 4, 2004 Share Posted September 4, 2004 You FI guys crack me up!!! All this talk about "lights", "codes", and "sensors". Sounds all techno-gizmo!! ...er...um...sorry to hear of your troubles...good luck... ...excuse me I have to go tear my entire bike apart to change my needle position... :grin: Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted September 4, 2004 Share Posted September 4, 2004 :pointup: Quote Link to comment Share on other sites More sharing options...
speedygeezer Posted September 6, 2004 Share Posted September 6, 2004 So, Dion, are you a happy-camper-rider yet? Quote Link to comment Share on other sites More sharing options...
Dion Posted September 7, 2004 Author Share Posted September 7, 2004 So, Dion, are you a happy-camper-rider yet? To be honest I'm a lazy fuck and haven't gotten around to it yet. Been to busy scrubin the new rear and just ridin. Finally stopped refilling the tank yesterday so I'll take look today. Quote Link to comment Share on other sites More sharing options...
