dante18 Posted July 9, 2004 Share Posted July 9, 2004 I bled my clutch line and put the clutch reservoir cap back on. When the handlebars are turned towards the left, there is clutch fluid leaking out of the seams. I tightened down the screws pretty tight on the reservoir but it's still leaking slightly. I filled the reservoir to the line inside. Any ideas? Thanks steve Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted July 9, 2004 Share Posted July 9, 2004 I would take it apart dry it and reinstall. If it still leaks a new rubber diaphram seal is in order. Quote Link to comment Share on other sites More sharing options...
dante18 Posted July 9, 2004 Author Share Posted July 9, 2004 Thanks...looks like I will replace the seal.... Quote Link to comment Share on other sites More sharing options...
Suf Daddy Posted July 11, 2004 Share Posted July 11, 2004 Dirt in the seal would do it. Mine had the top "cap" Then a plastic "shim", then the diaphram which I had to make nice and neat and flat. HTH - Suf Daddy Thanks...looks like I will replace the seal.... Quote Link to comment Share on other sites More sharing options...
