BIG BOY Posted June 25, 2004 Share Posted June 25, 2004 For the front rotor bolt pattern. Can anybody tell me the bolt hole measurements from the '97 - '98 wheel and the '99 on up wheel. Reason being i know someone that has a chrome front wheel, but doesn't know what year it is off of because the numbers are all ground down smooth before polishing before plating. Quote Link to comment Share on other sites More sharing options...
JasonW Posted June 25, 2004 Share Posted June 25, 2004 The measurement between each bolt hole on a '97-'98 is approximately 1.4375" or 1 7/8" and the I.D. of the rotor carrier is roughly 2.25". If the wheel is off, it would probably be the most accurate to measure across center from oposing holes....this would be approximately 2.875" or 2 7/8". I don't have calipers handy or a '99-up bird to measure. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Motobeagle Posted June 26, 2004 Share Posted June 26, 2004 so the 97-98 fronts are alike, and the rest are different? Quote Link to comment Share on other sites More sharing options...
