bajjer9
Everything posted by bajjer9
  1. something similar happened to me once and it turned out to be the oil filler cap was not tight and over time there was a small buildup of oil which dripped onto the exhaust. Now I make it a point to periodically check the tightness of the filler cap
  2. a 12v test light and some trial and error worked for me but then again I use to be an electronic technician
  3. I am on my third set of road pilots since I bought the bike in early '03 and I get from 10k to 14k on the rear and a lot more on the front
  4. Matey where did you get yours? Jaws? unfortunatley Jaws told me he cant get them anymore so I need an alternative source! mine has faded too much
  5. nope not stock, 16t on the front...and yes put the speedo healer on as well unfortunaely I put a positive value in and it indicated 120 at 80 (roughly) lol! Plus put the rear wavy disk,chain and a new set of rear pads on.
  6. gracias Tim! must be the cheap tools then!!
  7. Is the front sprocket bolt right hand or left hand thread? I am trying to put a new one on but I have broken a ratchet and a socket trying to get it off, its that tight!! Can anyone help?
  8. my bike was this way when I first bought it...it had dunlops on it with no visible cupping but based upon the reports of a lot of guys I opted to replace them with pirelli diablo tires. the vibration and high speed wobble i had, vanished completely...I now use michelin and still dont have any vibes...when it comes to this bike I wont put dunlops on ever again!
  9. anyone ever run a 15T front sprocket? I was told never deviate more or less than one tooth on the front. Is this right?
  10. bajjer9
    REAR DISC
    I ordered a wavy disk from Jaws if you want my old one let me know...however i might be a week or two before i get it coming from england
  11. heres a good write up of the R1 reg/rec swap...I cant remember what year you need but I think its 99 or 00...works well without cutting wires...You will have to remove the wires from the connector tho...I am about 1.5 years on mine and about 20k miles plus or minus 10k (cant remember exactly when I did it!) http://www.vlc.com.au/~justin/about/bikes/...eg_replace.html
  12. thanks, guess I need to do it again
  13. I changed my fork oil last night and this morning the first bump nearly sent my spine through the top of my head!! Once I started investigating seems I put too much oil in. The manual said 16.3oz and I put 16. Measured from the top with forks extended (is this part correct?) I discovered 140mm is NOT 1.4cm!! I cannot beleive I messed the conversion up!! How should this be done? Can someone spare me searching through 13 pages through the search function and break it down gently?
  14. bajjer9
    pilot jets
    i did a search for 99103-MT2-0430 and 99103-MT2-0440 but got no results however the 42 and 45 did so I must assume that 45 is the next size up from 42? yup from keihin site: 32 35 38 40 42 45 48 50 52 http://www.keihin-us.com/list.htm
  15. bajjer9
    pilot jets
    Thanks guys!!
  16. bajjer9
    pilot jets
    gonna take Maxx advice with my factory pro jet kit install and go up on the pilot jet but which on the ron ayers diagram is the pilot jet? I need to find a part number as a starting place. Anyone? http://www.ronayers.com/fiche/200_0351/car...580&parent=5570
  17. I went with silverstars for not much diffent than that...think it was 35 for the pair
  18. Can sea foam be used with carbed bikes as well? yea, i use it all the time on the advice of this board...works the same if not better then the chevron techron additive I used to use periodically to clean my system
  19. no one???? not even a penis joke or nothing? geez guess EVERYONE went to reno?
  20. Can anyone tell me the hose size that leads from the rear master cyclinder to the resevour (sp?) I am need to replace mine but my bike is not accessable today. Is it 3/8?
  21. I dont know much about the FI birds but can the throttle bodies be synced? I know it helped tremendously on mine but I have carbs
  22. damn man if i need something from you I will drive up there and GET it!! geez...oh by the way, wanna finance charles's bike for me? Thats the only way I could afford it!! that or winning the lotto but thats not likely as I dont buy lotto tickets!! besides I got the water wetter here at the local "fast and furious" shop
  23. I have that on my 97. Since its my only mode of transportation I was worried and changed my CCT (got one of the x-11 ones from Furbird last year) but that didnt totally solve my issue. My mechanic friend said it was fine so I been riding it since with no problems. but it still makes me nervous on the occaision where I notice it
  24. I had the same thoughts after reading the bottle but I stuck with the 50/50 with the measured amout of WW in it
  25. That would be affirmative. well then thats what i used...seems to have worked well, wished I had the digital gauge
