xxceptional
4 Neutral
About xxceptional
  • Birthday 04/28/1957
    70 Ct-70h 80 GS1000S H.D. Street glide
    Sarasota Fl.
1,268 profile views
  1. So I disassembled the whole switch and sure enough spraying the crap out of it with detoxit was not enough. Couldn't believe there was still so much dirt in there. So after some creative cleaning and some fresh dilectric grease on moving parts works and feels good as new. Thanks for the advice.
  2. Light don't turn on at all until relay starts clicking. Bike has 48k. I'm original owner always garaged and covered excellent condition. I have other bikes that I also ride but this one gets ridden at least once or twice a month. Been doing this for a couple mo. But just decided to fix it. After a lot of use its about 90 percent normal. I'm going to reverse wires and see if that narrows it down.
  3. The yoke that I speak of is inside the switch housing. It moves left,right or pushes in to disengage signal. The blinking is intermittent on right side only. Some times works Immediately sometimes waits for a few seconds and sometimes don't work at all. Did not try reversing wires yet.
  4. I've removed switch housing and tightened the Phillips head screw that was loose. Cleaned what I think are the contacts on each side and relubed up the yoke actuator mechanism but I still get intermittent turn signal on right side. It's much better than before. Blinker relay clicking normal. I would just buy a whole new switch if I could get one but seems 350250-mat-670 part is unavailable anymore. So what we do?
