Everything posted by silvertippr2001
thats a good thing on track days, but on the streets dosen't help, to much power and an a lot of wheel spining.
hello!!!!!!!!! any drag racers around????????
I want to make some mods to my bird, I'm thinking of some degrees on the cams. can some one tell me whats the stock degees on the cams and were shood I get the most out of it. right now Im running stock wih a full race yoshi sistem and power comander but i'm thinking to go with NOS. Any info of some experts from here woud be a lot of help. down here almost no one works with the xx. at the tracks there only 2 xx mine, and a 2000 that dosen't have any mods. I'd liked to grap the atention of those busa riders. P.S. what kind of stock cams do the xx 99 comes with?
I had a similar problem some time ago and all started with a full tank of a crap gas on a (I want to blow up) gas station. I had to take the injectors off, clean them and they were dirty as hell. I went nuts, just how you mite be now, but don't be, take it easy and trie to clean the injectors first. if you have the hanes manual thats all I had and I did it by my self. you just need some time and lots of "help me god" just kiding realy is not that hard. P.S I cleaned the injectors by my self too, I used a can fuel injector or carburator cleaner and a white cloth to shake the cleaner of the injectors. I used white to see the dirt coming of the injectors, mine had a lot of black stuff on it. hope that will help, it did for me !
I think it did but I can't check because the usb cale that came with the pc2 is not compatible whith my laptop I nedd to by one or some kind of adapter but thanks I'll check that. can any one tell me where I can find the service plug needed for the honda diagnostic test pin box , the thing is that here in Puerto Rico not even the honda stealer has it, I need to check the ecu
guys i've just install de pcII on my 99 bird and a 421 yoshimura race sistem but when a start the bike a fault code is indicated. she is showing code 10 I beleve thats the admospheric barometric sensor thats what the manual tells me. Have one of you guys seen that type of problem and what can I do if you haved. Thanks for any help
thanks will wait
what up guys question for all you experts I have troble staing on about 3k, the bike starts to stall, well better description is she stars like having intervals of electrical current but the engine kips runing. and if i open the throttle she runs great the problem is at low rev. anyone has any ideas :roll:
I saw that convertion on other site some time ago I dont realy remember the site but I think the price was some where around $400 or a little more
been there, don that That helped a little but still not mutch and she's drop 2 inches in the front and about 1 3/4 on the back every thing els is stock on the suspention I meen. I.m tring to leave the back end stock as muych as I can but I now some time soon I'm going to have to pull her back
thanks furbird I'll trie that the next time out and see what happens the thing is that have to fight with her when I go out and thats killing me on the first 60. another thing is that I'm a big m.f and I'm runing on 16/45 and I don't slip the rear, she comes up like a rocket lets see what I can do with that .
thats very correct blackhawk ,I'm having all kind of problems with my way out of the lights 5k slip the clutch and booom one wheel all the way it realy suks furbird do you now the site ,maibe I coud find a way to make the clutches to slip a little
What'up guys , can someone tell me if there are better set up clutch than the stock ones , for drag use . I'm doing some little upgrades to my 99 bird, I ride her hard on the street and visit the drag strip a few times a month, since you guys have more expirience than I (I'm just starting) and over here the xx is like something frome mars, people don't now how to make her run harder without lots of mods. As of now I'm making the busas shake a little since I'm asking, if someone throws in some sites that I could find some parts for drag aplications be realy thankfull. BURN RUBBER NOT YOURE ASS!!!!!!!!!!!!!!!!!!!!!!!!!
did.some.of.you.guys.have.expirience.with.s2000.injectors.on.a.bird alredy. and.if.yes.whats.the.output I.just.got.a.set.and.not.test.them.yet
the.plug.looks.clean I'll.go.with.wiring.problem.because.I'm.experimenting.other.problems.with.the.bike.to since.now.I.haven't.found.anything.wrong.with.the.wiring but.I.now.it.has.to.be.one I'll.kip.looking Thanks
guys,I'm.steel.having.problems when.I.tried.to.do.the.daignostic.once.I.install.the.jumper.cable.an.turn.on the.ignition.it.blows.the.instruments.panel.fuse. but.when.I.use.a.test.light.as.a.jumper.it.gives.me.the.f1.codes.like.its. supose.to Any.ideas?
thanks.Pete! beleve.you,me.is.more.beautiful.,when.youre.on.a.bird when.it.dosen't.have.any.problems.do.jajajajaj
it's.a.laptop :roll:
hey.guys.right.now.I've.just.about.anything.I.could.think.of.nothing.has. work.so.far,I.just.reseved.the.haynes.service.manual.and.did.step.by.step all.that.has.but.nothing.and.anyway.It.says.that.to.verify.the.TPS.it.has.to.be.on.the.dealer.with.honda.special.electronic.diagnostic.test.pin.box.(don't.now.what.the.f....is.that.thing)It.looks.like.I'm.going.to.die.on.the.dealer.anyway. If.someone.has.any.oder.Idea.please.let.me.now
I.think.I.did,XXti.but.I.took.her.for.a.spin.yesterday.but.for.short.time.she.was.runing.good,but.then.it.came.again.the.F......,lite.came.back.on. and.the.problems.again.,the.thing.is.that.this.time.she.started.shooting. throu,the.exoust.cans.and.the.revs.went.down.to.500.or.less.an.she.shot. down.but.did.not.gave.any.problems.to.start.back.on. I.yust.hold.open.the.throutle.all.the.way.to.11.5.and.wen.a.let.her.lose.she.almost.blow.the.cans.of.(caboooooom)and.all.came.back.to.the.normal. 1100.revs. I'm.wating.for.a.friend.to.download.the.file.so.I.can.read.how.to.erase.the.code.of.the.ecu.because.I.think.I.did.but.I'm.not.that.shoore.and.I.have. dialup, XNIKX: what.thats.supose.to.be.,erase.the.ecu.memori? If.is..that.I.shust.wroted.if.not.explain.your.self
Thanks.for.the.tip.XXTI.I.finish.cheking.the.grounds.of.all.the.bike now.I;m.taking.her.for.a.spin.and.see.what.happens. REDBIRD,thanks.for.the.file,but.I'm.going.to.take.it.to.a.friend.he.has.dsl. oh!.and.I.don't.haved.the.keys.twisted. the.thing.is.that.the.spacebar.is.broken.and.i'm.fixing.my.bird.fist. she.has.her.place.before.the.pc
PLEASE!.HELP I'm.having.big.problems.with.my.bird it's.stil.with.the.F1.light.on.and.the.tps.code I.have.not.found.the.problem.yet I.spoke.with.the.honda.dealer.here.and.they.told.me.that.the.tps.on.the. bird.its.very.hard.to.fail.and.that.if.it.is.the.tps.,the.thing.dosent.get.sold by.it.self,that.I.have.to.get.the.complete.throttle.body. They.told.me.to.verify.the.hardess.(did,that)and.test.the.TPS(don't.now.how) If.some.of.you.could.give.me.any.light.on.this.I.realy.be.thankfull P.S I'm.going.nuts
well.I.could.tell.you.that.runs.pretty.normal.exept.for.the.fact.that.it.feels.like.the.revs.ar.slow.and.when.the.f1.ligth.turns.on,it.tops.out.at.10k revs.and.dosen't.go.all.the.way.to.11.5k.like.she.normaly.do. it.feels.like.she.is.going.lean I.realy.don't.now.what.to.think.because.I.would.like.to.be.shoure.before.I.bye.the.(tps) thanks.for.what.ever.help.you.or.anyone.could.give.me
hello.guys.i'm.new.here I'm.having.problems.with.the.ecu,is.been.giving.the.tps.code. I.have.a.99.bird.with.13k.on.it,can.some.one.tell.me.if.is.adjustable.or.not. and.if.some.one.has.the.info.on.how.many.volts.or.omh.dose.it.throws,so.I.can.check.if.is.the.sensor.or.the.hardness. thans.for.any.help,I'm.desperado
