brianmacza
  1. the flat tip cover... should I drill the sucka out? means I can ride to work again!!!!
  2. Hi guys... EBC pads are great for stopping, but don't last too damn long. 11,000Km and the fronts are near metal2metal... Tried to get OE pads on Saturday, but the stealership parts counter isn't open on Saturdays to "prevent backyard mechanics from tainting their brand equity" - lameass excuse for "our workshop is bone-idle and need work" so... Got home, put the XX on mainstand, tried to remove abovementioned screws and they are tight as anything. Is there any KNOWN method of removing them without fucking them up completely in the process? I can get replacements (I think) from the stealership if I do, but I wanna ride my bike!!! Have put careful amounts of WD40 on both sides of the threat already - will wait and see if that helps
  3. I'll mike the holes and see whats involved. Will have to get some decent ally stock - my shit is all too small (biggest billet I have is 25mm diameter - prolly too small. Considered doing this a while ago, but ran outta energy :?
  4. there were pics on a website somewhere of a gutted XX muffler - was thinking of scouring the 'net and looking at what the gurus did and seeing if it could be replicated in a lighter/smaller format alternatively, I may just have to bite the bullet and buy some used slipons and modify them "'cos I can" Fortunately I have a lathe and milling machine available, as well as gas welding kit. The link tubes for slipons I can get from a local manufacturer for almost nothing (does a bottle of Jim Beam count as almost nothing??) http://www.bikersoracle.com/jaws/exhaust.htm some content:
  5. has anyone ever considered making their own slipons? The commercial slipons are too noisy for my taste... but I still want to reduce the weight of the bike by trimming back on the amount of metal in the pipes... any guesses on something with baffle plates similar to the real thang but maybe aluminium or titanium?
  6. beans... from Mexico... you guys need to go torch the fuckers in retribution for trashing florida :twisted: :twisted: just fit the damn HID so you can see what to shoot at!! :nana:
  7. The kit I have was H7 socket equivalent... pure plug and play don't stress... DO it fuckers!! :twisted: :twisted:
  8. c'mon guys... stop dicking around and DO it... Have both bulbs done now - best upgrade ever. :!: :!: :!:
  9. Yup.. still have it... 6000k bulb from " target="_blank">http://www.xenonlights.co.za/ B
  10. Remove the PC and see... take away the variables and you will ultimately be left with a solution.
  11. check that the fuel breather tube isn't pinched... you're probaby fighting a partial vacuum in the tank
  12. I personally like the silence of the standard pipes... yeah, they are heavy as hell, but there's a tradeoff for being able to whisper past a LEO at 120Mph and not get noticed
  13. The guy I bought the kit from is http://www.xenonlights.co.za/ His name is Johan, and he is prepared not only to split a kit up into 2 bike units, but will mix and match if you have 2 bikes with different bulb patterns.
  14. Installed my HID on low-beam yesterday - made an incredible difference The low-beam was a 55w Hella bulb, and I always found the output to be wishy-washy - the only time I was happy with the headlamp was if there were no cars about to show me how bad it really was. On a dark road I could see fine, but the light from passing cars or streetlights made me realise that I was partially blind at night. The HID installation has forced me to lower my beam considerably to prevent the lamp from blinding oncoming motorists - Measuring before and after I found that the lamp cutoff was at 41" (and I never got flashed by oncoming cars) - I had to lower it to 36 1/2" to keep people almost happy. This was measured with me sitting on the bike, off the mainstand and my kids running with bits of chalk - I'm in big shit with the amount of chalk on the wall :roll: The Light wash is now an intense rectangle that covers a 2-lane wall to wall, and extends out further than my previous bulb ever did. The installation was simple - plug the old spade connectors for the H7 bulb plug into the ballast, the bulb has a normal H7 type backing plate, and the ballast is cable-tied to the instrument cluster supporting frame. Installation took 35 minutes all told, apart from adjustment of the beam. All in all, a great upgrade - now I just have to find someone to take the 2nd ballast/bulb kit off my hands and I'll be a happy boy. I took photos with my trusty Nokia 9500 camera/phone/thing - will upload them when I can Before: After: The kit: (crap pic - I used my phone, dammit!!! :oops: Where it lives:
  15. fetching them tonite... will hopefully fit mainbeam this weekend and give report on monday.
  16. Mine occasionally clonks from 1st to 2nd... from other threads it seems to be a feature on the Bird. Some seem to advocate fully synth lube - 10w40 fully synth has been suggested as a measure to reduce said clonking noise Doesn't bug me at all... I frequently do clutchless changes and it slips past usually no sweat - but when it DOES happen it sounds horrible! :?
  17. about 35w per lamp I believe...
  18. I had never considered the load of the injectors and fuel pump... sounds reasonable in that case. I'm fetching my kit tonite - hope to put it in on saturday (will leave my high beam on halogen for a while and see the effectiveness of that combo - if it still needs help I can use the HID for high beam also) B
  19. There is apparently a slight delay as the ballast energises - dunno how long the delay is tho. On high beam you have both bulbs lit, so there would be no time where you don't have light. It would make flashing oncoming traffic a problem, potentially. The regulator on my bike appears to be working fine - no burn marks at all, and the charge appears to be within spec. The battery is a Huasa [sp?] japanes thang - might be a shit product, so I'll take a look at replacing it with a different make. The carb models have a smaller alternator output than the FI birds - the cause for my concern.
  20. My '97 gives me around 290km at the point where the reserve light comes on when I drive normally (I do the 80km dash to work in 30 minutes, door to door) and around 250km when I play with other riders The best I have ever had is around 340km to the point where the bike was juddering, and it took 21.3 liters (out of a max potential of 22!) decided to fill at the warning light from that point on :shock: oh, yes... stock pipes, no PC, K&N airfilter
  21. I just bought an HID upgrade kit - 2 x ballasts and 2 x H7 pattern bulbs total cost is ZAR2300 (or about US$350) - will install this weekend and see what the result is. Arctic - you SURE you don't wanna try a HID main beam? I only wanted a single ballast+bulb for low beam as my high beam is a Hella 80w that seems ok. If not, will do both and hope the delay on main beam switch doesn't piss me off too much. The big question here is - how many farkles CAN you put on a '97 bird without flatlining the electrical system? I'm wary of putting dual 55w lamps on main beam in addition to my 80w because my battery (tho' it is new - 4 months old) seems to lose charge while the systems appears to be charging properly.
  22. I have a similar problem with my '97 Bird. I have tested the charge rate and it seems within spec. The battery runs down if I leave the bike parked and don't use it for a couple of days. Funny thing is, if I bump start it it seems to start fine, the plug on the regulator isn't burned at all (no blackening caused by heat), and it seems to charge fine. The battery is new (but may be a dud - dunno about that part yet - will have to get it tested by an autoelec I guess) So I charge the battery on a trickle if I leave the bike for more than 2 or 3 days and that keeps me going - a crap compromise due to my laziness I guess.
  23. Hmmm.... I currently have a set of Bridgestone 010 front and 020 rear... just over 5000km for the set and the rear has only just started showing wear signs (the front has 8mm chicken strips and the moulding nubs are still on the sides 'cos I'm a woosie) - the last set was a 057 front 020 rear where the rear gave 14000km with about 2mm left when I changed it 'cos the 057 front was showing smooth rubber - no tread (at 18000km) Would like to look at the Maxxis next time round, failing which Metezler also looks like a reasonable warm weather tyre. unless of course the wisdom of the board can give reasons why these are crap decisions...
  24. does the katana have a solenoid on the starter, or a bendix? coukld just be dried grease stopping the movement
  25. tx will stroll downstairs and check justnow - drove to work this morning... quite chilly!! B
