XXitanium
  1. Same here. Back takes a pump or two to get brake. Front makes a clacking sound.
  2. ...not in the almost ten I've owned it.
  3. ...well after giving it thought, it may be the first time the top has been off since 2000. The leak I saw would have been the line not the casting in all probability. Maybe it's not a huge deal. Bleed the rear reservoir... I didn't do a very good look at the pad thickness. I should be drummed out of the garage.
  4. Did they really make two different housing castings? Looks like i might be able to replace the line if it's the problem. I couldn't make out how it assembles though. https://www.cheapcycleparts.com/oemparts/a/hon/506c2010f870023420a2f65a/fr-brake-caliper-r
  5. ...no pictures? I have something similar going on.
  6. Google brought me home. I was looking for part numbers on calipers right Vs left front. Does anyone have a link? ....OK, I have a soft rear brake lever and I,m losing brake fluid in the master cylinder very slowly. When my son dropped the bikes in the garage last summer, I noted a small drop from the joint where the metal tube meets the casting. It appeared to stop. I did however have to put fluid in during my ride last weekend. I'm guessing the caliper can't be repaired. I suppose it could be something else as well.
  7. That doesn't seem like a thing that should be too expensive to fix
  8. I'd love to have it, but I don't know how I pick it up or get it home.
  9. I will check in the morning. We're celebrating Roger's retirement...
  10. I have a "funny" clunk from the front calipers and the back takes two pumps to get brake. Took the cap off the reservoir- almost out of fluid. I got a can of DOT3 and filled it up. (Cover says DOT4) The clunk is still there. I think I'll ride as is because I've heard bad things about linked system bleeding going south. (Think this is a continuation of #3 dropping all three rideable bikes on each other two? years ago)
  11. ...there may be one on my son's 97 out in the garage...
  12. Did I tell you guys I bought the new gas tank for the hurricane?
  13. My 2000 bird doesn't chirp on a hard break grab.
  14. Who are you and what did you do with slapper?
  15. I'm not sure what I'm seeing. That looks like the outside of the assembly? ...passages would be really small holes inside the assembly, no? Sorry for being thick. I've never had to touch mine, y e t....
