Hello XX Forum,
This is kinda a long question but hopefully someone can help....
I recently bought a '97 Blackbird from a friend. He put Race Tech 1.0kg/mm springs in the forks (just springs no valving or emulators) and a Penske shock on the rear. He's 6'5" and weighs 230lbs and I'm 5'10", 170lbs. I already replaced the spring on the Penske, he had an 1100lb spring and I put a 1000lb spring on it. I called Penske and they said a 1000lb spring was recommended for my weight.
The problem is that I've played around with the compression and rebound adjustments on the Penske and it still seems harsh over bumps. I currently have the remote compression adjuster set at 2 (out of 6) and the rebound dial is about 8 (out of 30) clicks.
Is there anyone who's about my weight who also uses a Penske shock? If so, what are your settings?
Also, according to Race Tech, I am inbetween an .95kg/mm and 1.0kg/mm springs for the front. As stated above, the bike has the 1.0kg/mm springs in it. Would switching to the .95kg/mm be that noticeable?
I'm enjoying the bike and plan on using it mainly for touring so I'd like to have a cushier ride. I've already done a couple different 500+ mile days. The main comfort issue I'm having is with the suspension. It's great when the road is smooth but once the road gets a little bumpy (concrete block freeway with seems), feeling ALL the bumps can get old fast.
I haven't owned a "sportbike" before so maybe I'm expecting too much?
I'd appreciate whatever feedback or suggestions you have.
Thanks,
Ian
