Left passenger peg could be removed when fitting a 4-1 system, I think he wants to replace the right passenger peg with a plain exhaust hanger.
It's not difficult ot make your own.
Use stiff cardboard to make a template.
Get some 1/8" - 3/16" Al Alloy sheet, and copy your template - Voila
It can all be done with a handrill, hacksaw, vice, file, mothers, and the will.
Extra tip: Cover the Ally with a couple of layers of masking tape before cutting and bending the metal. Polishing is much easier and the results better without scratches.
Hey mechanic, since you're so close to me (I'm in Vancouver too), want to have a go for me?  ....
It's a possibility. Having seen the pictures of your steed I would suggest another alternative.
Pick up a RH passenger hanger on eBay (about $25 with postage)
Remove the peg.
Saw off the lugs.
File to blend and polish.
Really very easy, and would look the dogs bollocks.
You can get almost anything you need on ebay if you're patient - from my experience you should be able to score that part within a month.
never done the 'ebay thing', but should start as it would save me some bucks. If I wasn't being such a goof about the weight of my bike, I'd go for it, but there must be something out there. You've got a great idea and will probably follow your advice in the end. Thanks!
exactly what I meant to type...wow redbird, what a great guy to clear that up for me!
I was at work and in a hurry.
  • 2 years later...
