BigMig Posted October 17, 2010 Posted October 17, 2010 Team XX, I'm attaching Dual Star heaters to my bars and I don't know what's the preferred adhesive to use to bind my new grips (BMW sport) to the barsw dual star heaters. I guess there's a chance I'll eventually want to change grips and not destroy the heaters. Maybe I shouldn't worry about that. Any suggestions will be greatly appreciated. Mike Quote
Toynut Posted October 17, 2010 Posted October 17, 2010 You don't really to slather on much if any adhesive to get the job done (if at all). I would recommend you install a piece of heat shrink tubing on the clutch side bar underneath the heating element, otherwise the heat generated by the element will end up migrating to the clip on and the two bars will be two different temperatures. You can also clean the mold release agent from inside the grips to maximize their grip. Finally, a light coating of hair spray or spray trim adhesive is all you need if you want to use something to add a bit more stick to the job (probably not necessary). The only caveat is to install the grips quickly in their final position as you won't have much time to do it right before the adhesive sets up. Quote
Para045 Posted October 18, 2010 Posted October 18, 2010 Finally, a light coating of hair spray or spray trim adhesive is all you need if you want to use something to add a bit more stick to the job (probably not necessary). The only caveat is to install the grips quickly in their final position as you won't have much time to do it right before the adhesive sets up. Yeah I usually use hair spray or styling mouse and it works well Quote
BigMig Posted October 18, 2010 Author Posted October 18, 2010 styling mouse? I'm hair challenged, bro! Thanks, and thanks also to Al. I ended up doing the hot water soak of the new grip, followed by a tiny amount of gorilla glue pn the dual star. Seems to be ok. Will know in the AM. Mike Quote
Zero Knievel Posted October 18, 2010 Posted October 18, 2010 http://www.dual-star.com/index2/Rider/heated_grip_kit.htm Google is your friend. They list the recommended adhesive. Quote
BrittC Posted October 18, 2010 Posted October 18, 2010 I've installed Dual Star grip heaters under BMW sport grips on three of my bikes. Used hairspray each time and have never had a grip move once they dry. Smells much nicer than other adhesives! Quote
BigMig Posted October 19, 2010 Author Posted October 19, 2010 Notes to self: 1. grow hair 2. buy hairspray 3. install XX grips :--) Quote
Para045 Posted October 20, 2010 Posted October 20, 2010 styling mouse? I'm hair challenged, bro! Ha ha I just use the missus's Quote
OMG Posted October 22, 2010 Posted October 22, 2010 And the hair spray is the absolute best fuel for your potato gun. Quote
