BiKen Posted June 29, 2010 Posted June 29, 2010 These are metal plates that fit between each mirror assembly and the fairing and bracket. The rubber boot fits around the back of the plate between it and the fairing. These plates don't seem to be available as a spare part, only as part of the mirror stem, so if you've replaced a damaged mirror stem, it's likely you'll have a spare mirror plate. I need a LH and a RH plate, although they may be the same. Quote
Hobicus Posted July 1, 2010 Posted July 1, 2010 These are metal plates that fit between each mirror assembly and the fairing and bracket. The rubber boot fits around the back of the plate between it and the fairing. These plates don't seem to be available as a spare part, only as part of the mirror stem, so if you've replaced a damaged mirror stem, it's likely you'll have a spare mirror plate. I need a LH and a RH plate, although they may be the same. Let me dig though my parts bin tomorrow evening, I'll see what I have. I'm pretty sure I have a couple. Quote
ScottyUK Posted July 1, 2010 Posted July 1, 2010 These are metal plates that fit between each mirror assembly and the fairing and bracket. The rubber boot fits around the back of the plate between it and the fairing. These plates don't seem to be available as a spare part, only as part of the mirror stem, so if you've replaced a damaged mirror stem, it's likely you'll have a spare mirror plate. I need a LH and a RH plate, although they may be the same. Let me dig though my parts bin tomorrow evening, I'll see what I have. I'm pretty sure I have a couple. This dude's posted the same thing on a number of forums and I've already seen (a few days ago) the offer of some. Quote
Hobicus Posted July 1, 2010 Posted July 1, 2010 These are metal plates that fit between each mirror assembly and the fairing and bracket. The rubber boot fits around the back of the plate between it and the fairing. These plates don't seem to be available as a spare part, only as part of the mirror stem, so if you've replaced a damaged mirror stem, it's likely you'll have a spare mirror plate. I need a LH and a RH plate, although they may be the same. Let me dig though my parts bin tomorrow evening, I'll see what I have. I'm pretty sure I have a couple. This dude's posted the same thing on a number of forums and I've already seen (a few days ago) the offer of some. There are other forums?? I'll keep that in mind. Quote
