blkbrdrydr Posted December 30, 2003 Posted December 30, 2003 Several weeks ago, I added a PCII to my completely stock 2001. I felt that there was a bit of an improvement in the mid range and in the responsiveness. This weekend, I installed a set of Micron slip-ons and the bike almost feels as it did before the installation of the PCII. The responsiveness seems a bit slower and there seems to be a bit of hesitation when opening the throttle at 5,000 rpm in 6th. Any ideas before I install a map for Micron slip-ons with an OEM air filter? Quote
Northman Posted December 30, 2003 Posted December 30, 2003 Load the MAP for slip-ons that comes with your PCII software. If that doesn't work well enough, contact BigJeff, and he has a custom MAP for his setup. Try the one that comes with the software, first. Quote
blkbrdrydr Posted December 30, 2003 Author Posted December 30, 2003 I am trying to decide between removing the PCII or loading Big Jeff's custom map. Since none of the available maps for a non-European stock bike with stock air filter and slip-ons seem to be what I need even though M102-001 worked quite well before I installed the cans. What's the difference between mine and a European model anyway? 99-2001 Honda CBR 1100XX (99-2000 European Models) Maps Available: M102-ALL - All available CBR1100XX Maps M102-000 - Zero Map M102-001 - Completely stock bike M102-002 - Completely stock bike with modified ignition curve. Use 93 octane or higher fuel M102-003 - Full Micron "race only" exhaust M102-004 - Full Micron "race only" exhaust with modified ignition curve. Use 93 octane or higher fuel M102-005 - Full Akrapovic exhaust and stock air filter M102-006 - Full Striker (Hiper Dimension EX) exhaust and stock air filter M102-007 - Erion Racing full exhaust and stock air filter M102-008 - Erion Racing full exhaust and stock air filter with modified ignition curve. Use 93 octane or higher fuel M102-009 - Yoshimura RS3 full exhaust and stock or K&N air filter M102-010 - Yoshimura RS3 full exhaust and stock or K&N air filter with modified ignition curve. Use 93 octane or higher fuel M102-502 - European Model with Bos open slip-ons and stock or K&N air filter M102-503 - European Model with Bos open slip-ons and stock or K&N air filter with modified ignition curve. Use 98 octane or higher fuel M102-504 - European Model with Akrapovic full exhaust and stock or aftermarket air filter M102-505 - European Model with Sidekick open slip-ons & Db killers with stock or aftermarket air filter Quote
MiDNiTXX Posted December 31, 2003 Posted December 31, 2003 I think Jeff likes his map I like it too, thats what I was running. Quote
Big Jeff Posted December 31, 2003 Posted December 31, 2003 I think hitting the back button did that to me ??? Quote
