Motobeagle Posted December 10, 2003 Posted December 10, 2003 I found the French Mig instructions difficult to understand :wink: , so if this can help someone else, great. The mid pipes are a straight forward bolt on, so I'll jump to the silencers mounts. I had to make two individual cuts in my undertail, and rear fender. The undertail was mounted first. I used foam rubber insulation strips in between the undertail, and rear section for waterproofing. All of the hardware is fairly easy to figure out. Keep all of the harware loose until you have everything aligned(Mac's tip :wink: ). You may have to re-align later also. See them all at http://www.pbase.com/motobeagle/undertail_xx Quote
TOXXIC Posted December 10, 2003 Posted December 10, 2003 Jerry, Obviously, the pipes aren't here yet, but did you have to drill holes in the subframe? Or were the holes already in the subframe? Quote
Motobeagle Posted December 10, 2003 Author Posted December 10, 2003 Sorry man, I was in a rush. No, the bolts go through the joints in the subframe where the lower and upper subframe meet. It's actually a really nice mount design by Mig. The only tricky part was the cutting of the undertail, and plastic tail section. Quote
MaXX Posted December 10, 2003 Posted December 10, 2003 Wow, you have a Power Commander!!!!! Those things ROCK!!!! Nice Pics Beag. MaXX Quote
TOXXIC Posted December 10, 2003 Posted December 10, 2003 What did you use to make the cuts? Jig saw, dremel, or razor knife? :???: Quote
bajjer9 Posted December 10, 2003 Posted December 10, 2003 Tim I used a coping saw...worked quite nice on the plastic and was easy to move around James Quote
BIG BOY Posted December 10, 2003 Posted December 10, 2003 I didn't get foam with mine??? I'm sooo jealous. Quote
Motobeagle Posted December 10, 2003 Author Posted December 10, 2003 Tim, I used a dremel, and a file. Don, I gots plenty of rubba fo you. :wink: Quote
Sk8boardIL Posted December 10, 2003 Posted December 10, 2003 sorry for the OT, but where did you order the undertail from? The Mototek is just beautiful. Quote
birdie_xx Posted December 10, 2003 Posted December 10, 2003 Sk8boardIL, not that your new avatar isn't cute (it is ! :twisted: ), but would you mind to bring your old one back , please.... ?:wink: Cheers, :cool: Quote
Sk8boardIL Posted December 10, 2003 Posted December 10, 2003 mission accomplished: blackbird is back in action! not big into rice rockets??? Quote
Northman Posted December 21, 2003 Posted December 21, 2003 Jerry, did you make that plate to mount the PCII on? If so, got the plans, or an extra stored somewhere? :wink: Quote
