EVLXX Posted December 23, 2007 Posted December 23, 2007 I recently came into the posession of a Generac electric generator that's been sitting for a few years. It's a 16 Kw Natural Gas unit.. and that's about all I know. Since It's probably going to be sitting around here for a while... owners live out of town... I figured I might play with it and see if I could get it running for them. But here's the rub.... I've never worked on a N.G. fired piston motor. I was wondering if I can hook up a Propane bottle for an alternative fuel source, but I'm not sure if it would need to be a liquid propane bottle or a gas... OH ya ... and there's no operator's manual either... Does anybody here have any experience in this area ? Quote
RichardCranium Posted December 23, 2007 Posted December 23, 2007 I recently came into the posession of a Generac electric generator that's been sitting for a few years. It's a 16 Kw Natural Gas unit.. and that's about all I know. Since It's probably going to be sitting around here for a while... owners live out of town... I figured I might play with it and see if I could get it running for them. But here's the rub.... I've never worked on a N.G. fired piston motor. I was wondering if I can hook up a Propane bottle for an alternative fuel source, but I'm not sure if it would need to be a liquid propane bottle or a gas... OH ya ... and there's no operator's manual either... Does anybody here have any experience in this area ? Just send it to me. I'll fix it. Quote
JoWhee Posted December 23, 2007 Posted December 23, 2007 You can probably google a manual. Propane and NG have different properties, it may or may not run if you use propane in a NG engine, or it may run poorly. If it has spark plugs remove them shoot some oil in the cylinders and hand crank it to make sure the engine isn't seized. If there's no spark plugs it may be a converted diesel in which case it should burn just about anything. Quote
EVLXX Posted December 23, 2007 Author Posted December 23, 2007 Just send it to me. I'll fix it. You didn't tell me you used to be a mechanic .... ! ... Anyways, you want me to ship it to Oklahoma... so that you can fix it and then YOU can deliver it to its new owners, and take all the credit ? Ha... I don't think so. ... Besides, why would I want to do that ? That would be taking half of the fun out of it, for me anyway. .. Well see'n as how I have the next week off, maybe I'll play with it... That's if I can get it in the garage.... F'n thing weighs a ton... nearly killed me getting it outa the truck without a forklift. I'm guessing it weighs around 5-600 pounds. . or maybe I'll just let'r sit, till I can deliver it too them this coming spring. . Not sure I can do that either.... Anybody else got any bright ideas ? Quote
SwampNut Posted January 10, 2008 Posted January 10, 2008 Do not hook it up to LPG if it's made for CNG (or the other way around). Most are convertible, and I saw one that simply needed to have a setting changed on the carb. Quote
