HERBXX Posted July 8, 2003 Posted July 8, 2003 IF anybody has the time i would like to know how many threads are visable under the collar that compresses the rear spring on your shock. I was so excited to get the ring nuts loose i forgot to take note of the factory setting before turning them an unknow amount . I think i moved them about 1.5 or 2 turns but im not sure. BTW i got it loose on the bike with a puch, alternating taping the top and bottom, nut in different direction till the top (jam nut) came loose. Thanks Herb Quote
AlphaBird Posted July 8, 2003 Posted July 8, 2003 IF anybody has the time i would like to know how many threads are visable under the collar that compresses the rear spring on your shock. I was so excited to get the ring nuts loose i forgot to take note of the factory setting before turning them an unknow amount . I think i moved them about 1.5 or 2 turns but im not sure. BTW i got it loose on the bike with a puch, alternating taping the top and bottom, nut in different direction till the top (jam nut) came loose. Thanks Herb Shouldnt make any diffrence---you want to set the sag via the spring preload---tighten it until you have about 35-30mm of free sag(diff in rr bike height between between a unloaded and full loaded) Quote
Big Jeff Posted July 8, 2003 Posted July 8, 2003 You'll probably end up maxing the preload before you get the correct sag. Quote
