Manual says to replace washers for where the hose connects to the tank,
basically its a banjo type fitting with crush washers, will it leak if I use the old washers?
Thanks,
Ken
I've had mine off at least 10 times, with no fuel leaks upon re-assembly.
Just like the oil drain plug washer. I've never replaced that, either, even though the manual tells me to with each oil change. :roll:
