brianmacza Posted July 1, 2005 Posted July 1, 2005 Hi folks... My rear brake has become hard to press down on... almost no retardation on a full-weight push with new OEM honda pads... the pins are lubed and I dunno what else to look out for. Any suggestions? B Quote
Pete in PA Posted July 1, 2005 Posted July 1, 2005 That's bizarre, :? I would start with a full change of all the brake fluid. Whats it look like? Quote
Dion Posted July 1, 2005 Posted July 1, 2005 Make sure the pads are in correctly and not cocked in the caliper. Quote
The Krypt Keeper Posted July 1, 2005 Posted July 1, 2005 cocked you said cocked definetly sounds like something is misaligned... Quote
JB4XX Posted July 1, 2005 Posted July 1, 2005 cocked you said cocked definetly sounds like something is misaligned... Screw "misaligned" I like it when Dion was saying it's "COCKED" Quote
Northman Posted July 1, 2005 Posted July 1, 2005 Check for siezed linkage at the lever/rear master cylinder, and check the condition of the brake fluid as well. How many miles, and do you perform any regular service on the bike? Anything brake related prior to this problem? Quote
Mr dos equis Posted July 1, 2005 Posted July 1, 2005 Make sure the pads aren't COCKED! Then BLEED it with new fluid! Quote
The Krypt Keeper Posted July 2, 2005 Posted July 2, 2005 Make sure the pads aren't COCKED! Â Then BLEED it with new fluid! I will cock you till I make you bleed... I havn't been very useful in this thread.. :oops: Quote
brianmacza Posted July 2, 2005 Author Posted July 2, 2005 The brakes were great, pads reached end-of-life, swapped pads out and everything was fine until earlier this week when the sucka started acting all tuff with me. Now I have to REALLY stand on the lever to get any effect at all... Will lewk @ linkages, fluid, mindset and so forth right now. Tx for the advice guys... muchas appreciated B Quote
brianmacza Posted July 2, 2005 Author Posted July 2, 2005 I just took the pads out and lubed the caliper sliders - they were siezed SOLID. Amazing what can change in a couple weeks.... took the opportunity to suss the pads out and they seem ok. Also felt guilty, so I washed and waxed for the first time in a month... she lewks gudjas again!!! Quote
Mr dos equis Posted July 2, 2005 Posted July 2, 2005 Dude is that some kind of sick come on line you use? Cock and bleed this... :flamethrower: Quote
DBLXXTC Posted July 2, 2005 Posted July 2, 2005 seeing the word "cocked" got me all giddy too... Quote
